November 22, 2008, 10:51:30 AM
| | |-+  need info/pics on rear brake hoses
Author Topic: need info/pics on rear brake hoses  (Read 300 times)
jet-taz
« on: March 04, 2006, 11:19:27 AM »
for those using a b-body 8 3/4 rear . what are you using for a rear flex hose.?
qkcuda
Caledonia, ON Canada
Re: need info/pics on rear brake hoses
« Reply #1 on: March 04, 2006, 04:03:00 PM »
I have an A body 8 3/4, but this is an issue nobody ever mentions.  I have super stock springs, and I used long shocks, so you need a longer brake hose.  You don't want the brake hose acting as a limiter or pulling apart.  I found a Wagner BH 50396 which is 3-4 inches longer than stock, and has the same ends.  I often wondered if the guys who thought their shocks were topping out, checked the brake hoses at full extension.
70 Dustpan
Sacramento CA.
« Reply #2 on: March 04, 2006, 09:21:16 PM »
I have a stock B body one on the Duster and a SS braided one on the Valiant.
Hey, I'm a God again!
jet-taz
« Reply #3 on: March 04, 2006, 10:57:55 PM »
here's where  i need info. all of the flex hoses shows female ends, i think i'll need one to be male.the one in the photo won't help because the brake lines  to the cylinders won't line up.
dartracer
Strasburg CO.
« Reply #4 on: March 05, 2006, 06:55:57 PM »
I just bought the one in the pic and tryed to put it on my 81/4. The flex hose is not long enough for my Barracuda not even close. The 81/4 had that same hose on it when I got it.
mopartranman
« Reply #5 on: March 05, 2006, 09:29:58 PM »
I cut the bracket and weld in a peice to extend the bracket down closer to the rearend. Then use the hose it calls for.
qkcuda
« Reply #6 on: March 06, 2006, 10:39:07 PM »
Here is a pic of the brake hose I posted the part number for.  It has a female fitting on the bracket end with the proper lock ring groove and a male fitting on the end that fits into the tee.  It is 21 inches long tip to tip.  Hope this helps.
jet-taz
« Reply #7 on: March 06, 2006, 11:11:35 PM »
that's the baby.  ordering one on tuesday. thank you thank you thank you thank you thank you thank you thank you
Brad4406
Bellevue, NE (near Offutt AFB)
« Reply #8 on: March 07, 2006, 11:02:30 AM »
I don't know what the part number is, but I went with one for an '86 Ram 4 X 4 so I knew it would be more than long enogh when the suspension expanded at launch.  But that one that gkcuda shows should leave you a bunch extra since it looks even longer than the one for a 4 X 4.
Brad
Brad4406
brawn4406@yahoo.com
Hungry?  Need a job?  Eat your import!
