July 05, 2008, 12:53:13 AM
| | |-+  repace roof to the original sunroof
Author Topic: repace roof to the original sunroof  (Read 118 times)
norway_dartsport
norway_dartsport
« on: May 18, 2008, 08:40:59 AM »
my 1974 dart sport is a orginal sunroof car... but it rusted and the prevous owner cut it out and welded in a ricer roof ... my questino is : are the sunroofs any good in these cars ? do they leak ? are they hard to fix ? should i replace my roof with one with out sunroof Huh
dartracer
Strasburg CO.
Re: repace roof to the original sunroof
« Reply #1 on: May 18, 2008, 09:10:50 AM »
If it works and looks good, I would leave it there.
67Dart34dr0
« Reply #2 on: May 26, 2008, 12:13:20 AM »
The most important question is if you want it to be original. It will not ever look 100% stock, but you may get it to look pretty good. It is all dependent upon what your perspective is, but I do not see any benefit in converting to a non-sunroof. If you wanted to replace the roof,  replace it with a factory sunroof roof. (it is so much effort that you might as well get the car all the way back) The possibility is also there to find a decent sunroof and cut it out and weld it in.
1967 Dodge Dart 270 4-door
'72 340 (9.5:1), '72 727 Torqueflite, '72 8-3/4" Rear, '73-'76 Big Bolt Discs, Repaints, Original Interior, Possibly Original Miles, stock '72 valves, Factory A/C
fourspeed
Wisconsin
« Reply #3 on: May 26, 2008, 01:46:44 AM »
Is this the crank style with the tracks that go under the roof? I'll assume so.
They are unusual.
do they leak ?
Most of them do.
Yes.
That would be a lot of work... and not easy. Finding and installing a factory sunroof would also be difficult. If the car is stored indoors, I guess a sunroof would be ok. Did it have a vinyl top from the factory?
