July 06, 2008, 10:18:18 AM
| | |-+  What Hood Scoop?
Author Topic: What Hood Scoop?  (Read 542 times)
mopowers
What Hood Scoop?
« on: May 18, 2008, 03:30:19 PM »
What hood scoop do I need to run this induction set-up?  Its a low deck with a Victor manifold, 1" spacer and 4150 carb.  Is anyone running this same set-up?  THANKS.
2006 Dakota
68dodge
Re: What Hood Scoop?
« Reply #1 on: May 18, 2008, 08:09:28 PM »
I would set it in the car and see how high it does set, then decide which one work best.
mopowers
« Reply #2 on: May 19, 2008, 10:05:44 PM »
Yeah, that's probably the smart thing to do.  I'm just trying to figure out what kind of scoop would look best on a 66 dart.  I really like the sixpack scoop.  Hopefully it will clear.
2006 Dakota
Womanator
Womanator Racing
« Reply #3 on: May 20, 2008, 01:30:11 PM »
I'm running a 400 based engine in the 68 dart with a indy manifold and a 2" spacer with a dominator carb with a hemi hood scoop and it will fit under the scoop.It will fit with an arrow scoop also.Click on the Rams head for a picture.
fasttcars
« Reply #4 on: May 20, 2008, 02:22:47 PM »
.oh i noticed you finally picked up a carb  which one did you go with?.......
mopowers
« Reply #5 on: May 20, 2008, 10:12:14 PM »
Thanks guys.
I ended up buying a stage 7 BIGS 950.  It's got a lot of cool features- billet metering blocks and base plate, I think the venturis have been smoothed out, secondary jet extensions w/ notched float, and some other goodies.  I don't know if it is standard now, but I also noticed the secondaries are easily adjustable without taking the carb off.
Here is a link:
http://cgi.ebay.com/ebaymotors/BIGS-950-HP-Stg-7-Double-Pumper-Holley-Carburetor-Carb_W0QQcmdZViewItemQQcategoryZ33550QQihZ005QQitemZ150247652133QQrdZ1QQsspagenameZWDVW
The one I got was very slightly used for $500.  I've already taken it apart and checked things out.  It's got 76 primary jets and 83 secondary, 28 squirters (both), 4.5 power valve (primary), secondary has no power valve.  Should I use one in the secondary side?  Also, should I get some bigger squirters (28s seem small to me)?
2006 Dakota
tony GTS
Higher Performance
« Reply #6 on: May 21, 2008, 07:52:39 PM »
drive it before you adjust it, bigger squiters wont give you a sharp stream of gas like a 28 will
Womanator
Womanator Racing
« Reply #7 on: May 22, 2008, 12:07:10 AM »
Indy manifold and 2" spacer and a 4500 carb
Right wing not bolted on.Just put on so you can see it
« Reply #8 on: May 23, 2008, 01:03:24 PM »
In my RR with an RB, Eddy RPM's, victor manifold 2" adaptor and a Dominator it had to run without the 6 pack hood as it didn't fit with the air filter.
The Dart uses a cowl induction hood with a SB 408, EddyRPM's,  RPM air gap and a 70 440 AVS and it is very sensitive to the air cleaner's location under the AAR hood. Darts look evil with the cowl induction, IMO.
75Dart440
« Reply #9 on: May 28, 2008, 10:06:20 PM »
I had the Victor intake and edelbrock 750 on my 440 in a Dart Sport and tried to fit it all under a factory twin snorkel scoop, but I couldn't fit any kind of decent sized air cleaner under the scoop.  This was without the 1" spacer.  If I had to guess, I'd bet that you would need at least 4" or more above the outer hood skin.
1975 Dodge Dart Sport - 440
2000 Dodge Ram 1500 QC 4x4
mopowers
« Reply #10 on: May 28, 2008, 10:22:21 PM »
How much taller is a 440 than a 400?
2006 Dakota
fasttcars
« Reply #11 on: May 29, 2008, 06:56:01 AM »
about 3/4 of a inch
