November 22, 2008, 12:07:38 AM
| | |-+  Hot ignition resistor (normal?)
Author Topic: Hot ignition resistor (normal?)  (Read 97 times)
MVRCorp
« on: May 20, 2008, 01:33:31 PM »
My car started spitting and sputtering this morning for some reason. How hot should the resistor get? I can barely touch it.
ksdartguy
Re: Hot ignition resistor (normal?)
« Reply #1 on: May 20, 2008, 01:40:59 PM »
It will likely burn you. They get pretty darn hot.
I doubt you could leave your hand on it. Shocked
Rick
