July 24, 2008, 12:40:52 AM
| | |-+  So what happened now?
Author Topic: So what happened now?  (Read 211 times)
67barracuda
« on: May 21, 2008, 08:24:05 AM »
Well, I got my carb back form Barry Grant and installed. When I was trying to start the car, it got running for a second and it stalled. I adjusted the timming getting it closer. Theis happened a couple of times. When the next time I went to crank over the motor,all I got was a single click and the whole system was shorted out to the body. So, when I took my test  like and went from the - on ghe battery to the body of the car, it lite up. If I went from the + of the battery to the body nothing, so there is a short, but what would  suddenly short? Would the starter relay on the inter fender do this, or could the starter do this? I didn't really get into it very deep last night as I ran out of time. Any one have any ideas?
doug 371
Re: So what happened now?
« Reply #1 on: May 21, 2008, 08:35:29 AM »
bad body ground
Gospel Runner
gospel_runner
« Reply #2 on: May 21, 2008, 10:16:52 AM »
Check for fried wires. From alternator to voltage regulator and vacinity. Good luck!!!
« Reply #3 on: May 21, 2008, 11:20:30 AM »
Doug is right. Your light doesn't show a short, it shows an open.
67barracuda
« Reply #4 on: May 21, 2008, 12:13:34 PM »
I'll double check the ground off the battery first thing after work.
thank, I sure hope thats it.
satellite65
Long Island, NY
« Reply #5 on: May 21, 2008, 10:21:16 PM »
bad body ground
agree  If you're reading voltage from B- to the chassis you lost your ground. (I highly doubt it had anything to do with your BG carb-just a coincidence)
