October 12, 2008, 05:06:59 AM
| | |-+  B/E Body question?
Author Topic: B/E Body question?  (Read 210 times)
TrxR
B/E Body question?
« on: May 21, 2008, 02:17:26 PM »
I should know the answer to this question but I want to be sure. With a E body and pre 71 B body do the K frames need to be changed to swap from a small block to a big block or  do they use the same K frame and just different mounts?
Thanks
Long Island, NY
Re: B/E Body question?
« Reply #1 on: May 21, 2008, 02:33:01 PM »
I'm ALMOST POSITIVE you can put a small block or a big block on the same K frame on a B. The only reason I'm not sure is that I've never had anything other than a big block.
Capt Jack
« Reply #2 on: May 21, 2008, 03:05:43 PM »
I do believe its just the mounts that are the diff for B's.  they came with every possible engine option, so rather than have custom K's for each, the mounts were varied.
hope so, the coronet is starting to look like its going from SB to BB.  lord knows theres plenty of room for either
« Reply #3 on: May 21, 2008, 04:22:56 PM »
Yes, small block and big block used the same k-member. I believe slants were different and I know hemis were different.
« Reply #4 on: May 25, 2008, 09:32:46 PM »
Somebody should tell the professional swap meet jerks that! $250 for a K member and $275 for a BB \/][  What a bunch of rip off artists! bat
sst3193
« Reply #5 on: May 27, 2008, 04:09:43 PM »
Had a '74 Cuda with a 440 under the hood, originally a 318 car. The BB sit a little higher(1.5") in my car than the friends original BB car engine did, but it did bolt right in. Trans mount bolted up too, only real difference for me was better ground/header clearence and a taller scoop on the hood.
