October 07, 2008, 06:33:20 AM
| | |-+  Who has run 2x3 frame connectors into the rails?
Author Topic: Who has run 2x3 frame connectors into the rails?  (Read 608 times)
ab7fh
« on: May 23, 2008, 06:30:19 PM »
Who has run 2x3 frame connectors into the rear frame rails?
I've seen a thread about this before, but can't seem to find it. I'd like to see some pics of this type of installation.
 thank you
mopwr2004a
Re: Who has run 2x3 frame connectors into the rails?
« Reply #1 on: May 23, 2008, 07:32:34 PM »
I just did mine into the rear frame rail it takes a little work I don't have any pictures to post right now I have to load them to my puter still. I will try to post some soon
ab7fh
« Reply #2 on: May 23, 2008, 08:00:55 PM »
Thanks that would be great.
72 Swinger 394/727/8.75
« Reply #3 on: May 23, 2008, 08:03:07 PM »
Here is a couple shots of mine.
ab7fh
« Reply #4 on: May 23, 2008, 08:15:15 PM »
That plate that's sticking down. Did you use that tie wrap back into the frame??
Thanks for the pics. Very helpful.
« Reply #5 on: May 23, 2008, 09:15:11 PM »
yes and no. That was the original intent. Now they are trimmed up and not there anymore. Got in the way of Brake lines and Fuel lines......the original subframe is sandwiched between the 2X3 and a plate that cups the original subframe. I rosset welded the subframe to my connectors that were slide in and then I rosset welded 2X3 that was cut in half over the subframe.....OVER ENGINEERED. Glad I could help! Grin
268darts
« Reply #6 on: May 24, 2008, 12:57:10 AM »
I dropped some 2x3 tubing into my frame when I replaced the floorboard in my car. The rails are not in lign, so I cut a small "V" on opposite sides of the tubes. Then trimmed them a little to make them lign up. Tac the "V", take the 2x3 out and weld it up, then drop it back into the frame and weld.
« Reply #7 on: May 24, 2008, 08:58:13 PM »
Alain
« Reply #8 on: August 19, 2008, 04:22:42 AM »
I did this to my Dart and also added a 4 link. Now I'm a bit stumped over where to run the fuel lines. I will need 2 lines (probably about 1/2") because I need a return for the EFI. Anyone have some pics of this?
Later,
~Alain~
