October 10, 2008, 10:04:00 PM
| | |-+  Steering linkage help
Author Topic: Steering linkage help  (Read 143 times)
MoPar_or _NoCar
« on: May 28, 2008, 11:21:17 PM »
Put center link in before or after installing B motor in 68 Dart? Has SB K frame, 8 qt pan, power steering, shumacher biscuit conversion and headers. Would like it to roll again. Thanx
signet
Re: Steering linkage help
« Reply #1 on: May 28, 2008, 11:44:46 PM »
hey.
the centerlink can be bolted up after no problem if the pan is right.
what you may want to do is remove and reweld the lip in that K-member for improved clearance were it gets close to the front of the pan.
did you modify the area were the oil pump comes close to the engine mount bracket?
anyways i have had no problems with the center-link hooked up, but the oil pump and front of the pan and the pinch weld in the trans tunnel all were on the "round-2-it" list.
take care
MoPar_or _NoCar
« Reply #2 on: May 28, 2008, 11:51:20 PM »
Those mods are all done. Just wanted to make sure I didn't have to take it apart again. Thanx Alot !!!
