August 21, 2008, 09:28:19 PM
| | |-+  ignition wiring ?
Author Topic: ignition wiring ?  (Read 145 times)
grudd440
ignition wiring ?
« on: May 28, 2008, 11:34:09 PM »
do i run the hot wire from the switch to the neg. or pos. side of the coil?
doug 371
Re: ignition wiring ?
« Reply #1 on: May 28, 2008, 11:37:57 PM »
pos...neg to the dist.
Allentown, PA
« Reply #2 on: May 29, 2008, 06:16:38 PM »
what are you using for an ignition system ?   if it is electronic you do not hook the key to the coil the ignition does it for you ... if it is points yuo need to go through a ballast resistor 1st
grudd440
« Reply #3 on: May 29, 2008, 07:20:46 PM »
points style. im just trying to get an engine running.
grudd440
« Reply #4 on: May 29, 2008, 07:57:36 PM »
im hooking it up:  switch to ballast resisor, ballast resistor to pos. side of coil, neg to dist.
