Topic: pics of my new interior (Read 625 times)
mrspeeddemon
I finally got my car togather and figured I'd show off my dash. I used an old beat up console from a 69 Barracuda and fixed it up, I stole some buckets from a 74 valiant brougham that I recovered with covers from Legendary to match my chery back seat, and my dash is a redline carbon fiber insert(the carbon fiber is flat-the black is textured)and some Equus gauges with an autometer shift light. I added the wood grain just to tie everything togather and maybe look a little stock?
MoPar_or _NoCar
Very Nice !!!
dartracer
Love the foot, very old school.
thebankerstoy
Your aftermarker shifter in the factory floor console looks great, I'm going to do something similar in my 66 Coronet.
Richard
my, what a big toe you have!!!! very nice.
smallbigblock
Wow! love the foot, great dash - I am planning something like that, hope it turns out that nice
I should have left it alone
Bigcube
Looks awesome! I could use some pointers on wiring the high beam and turn signal indicators  I'm about to attempt putting my insert in this weekend
mrspeeddemon
I just used my wiring diagram from the shop manual and match up wires from the old harness to what I have now. -I did turn the old oil pressure light wire into the tach wire since I'm now using mechanical gauges.
Bigcube
Shop manual  I don't need no stinking shop manual, I have the internet  Seriously I have a color code for them all... I just haven't looked close enough at the dash plugs but it seems like I had more wires then my color codes. What did you do with the 2 big leads that connect to the factory ammeter?
mrspeeddemon
I actually eliminated them, but at the same time I wired the dash I rewired the entire engine compartment. I added an MSD ignition and a toyota alternator so all the factory chrysler electrical is gone.
68dodge
Looks good. Very nice.
DartGTDan
71 Dart GT (1 of 1255)
mrspeeddemon,
Looks great! I'm planning on using the RedLine insert in my '71 Dart GT (swapping in a '70 Duster dash panel). What size are those gauges you used? I will be using 3 3/8" diameter for tach & speedo, then 2 1/16" diameter for water, oil, volts, & fuel level. I also plan an adding 6 toggle switches to replace the headlamp & wiper switches. Also adding 5 LEDs (L & R turn, high beam on, oil, & brake indicatrors). I'm hoping I'll have enough real estate for everything.
Dan
1 of ~1255
mrspeeddemon
yeah they're 3 3/8" and 2 1/16"- and things are definately tight! I couldn't fit anything else in there- well maybe a toggle or two. But I mounted my wipers and headlights in the dash(look closely at the pics) which definately makes it look alot cleaner. I almost gave up on the shift lite because of the lack of room.
67Dart34dr0
Sweet car. Does it still get 36 mpg?
mrspeeddemon
I don't think so- I haven't actually tested the new mill for mpg.- maybe if I coast down some really big hills it might
67Dart383
Like what you have done, question, why toyota alt?
67 Dart 383 MP590, Crane 1.6 R/R, headers, 906, 850 MIghty Demon, Performer RPM, 3inch exhausts, 727 R/M, 9.5 PTC 4500 flash stall w/ 2800 brake stall, 8 3/4 rear with P/T 4.30, on MT ET St Rad 11.77@112.97mph
mrspeeddemon
its smaller, lighter, and internally regulated so simpler.
