Topic: Electric control panels?? (Read 142 times)
CA Duster 383
This is for a race duster, has anyone used one of the aftermarket control panels with starter button and switch's for fuel pump, fan, etc??
What brand did you choose and were you happy with your choice?
I plan on keeping the ignition key in the steering columb, but only for locking the steering wheel when parked.
The whole car needs to be upgraded as far as wiring goes and I don't need accessory stuff like stereo or A/C-heater.
Opinions please.
sunsetdart
CA...........Painless makes a couple different panels, with a number of switches. If you want to save youself some cash, buy the switches separetly and put them in a panel you make yourself. Check Jegs or Summit for either/or
Prodart
My dart has the Moroso rocker panel for the dash . Been a good piece just make sure to use relays the breakers don't like 20 amp draws. The wifeys Elco has a Chassisworks toggle overhead panel. It comes with the cage mount and has buss type fuses. Its more forgiving on the higher amperage draws.  Mark
