Topic: Rack and Pinion mounted to a stock K-member (Read 734 times)
RaisinBran
Has anyone ever mounted a rack and pinion to a stock k-member? Can't afford Bill's k-member, but do need to convert to rack and pinion steering do to the Hemi w/ custom fabed headers. Stock steering will no longer fit.
 10.71 @125
rokketride
Online
Not to be confrontational in any way, but if you're doing a hemi conversion you're already spending a small fortune. What's another $3-4k?
Now, bear in mind that I'm still running modified stock front suspension and probably always will. So I don't think every one of these cars needs an aftermarket suspension system, but you're going to spend a lot of time trying to re-engineer something and you probably won't save as much as you're thinking. Add up the cost of all the rack related parts and then the front end rebuild, new torsion bars, shocks, etc. I'd be surprised if you saved $1k.
RaisinBran
Thanks for the link thats exactly what I was looking for!
 10.71 @125
Online
I'll bet it's got Ackerman problems...................
rokketride
 it's made to go straight, has zero bump steer and not recommended for the street.
RaisinBran
Thanks bOb shingler for the pic! This will be race only also. It is for a customer, I can only recommend an alterkation, but ultimately its his money and decision.
 10.71 @125
Prodart
With that angle on the rack . I bet it bump steers like a Biatch too..................
RaisinBran
Shouldn't be a problem in a Drag car with no bumps right? The car has allready been converted to a Hemi and custom headers built and installed without any room for the stock steering setup. This will have to work. Thanks for everyones help!
 10.71 @125
blown71duster
I personally dont have one but , My guess would be for a street car that wants modern rack and pinion type steering (tight feel with power assist) with the tie rods in the factory location , just pointing out options.
1971 Duster 440 Single turbo
RaisinBran
I personally dont have one but , My guess would be for a street car that wants modern rack and pinion type steering (tight feel with power assist) with the tie rods in the factory location , just pointing out options.  I have no room in the factory location. That is why I am looking into mounting it in the k-member.
 10.71 @125
blown71duster
I have no room in the factory location. That is why I am looking into mounting it in the k-member. Understand, if ya wanted easy you would leave it stock (boring) , and worry about things like how did the factory paint this.
RaisinBran
Understand, if ya wanted easy you would leave it stock (boring) , and worry about things like how did the factory paint this.  Thanks man, by the way speaking of not boring looks like you got a turbo on your mopar?
 10.71 @125
With that angle on the rack . I bet it bump steers like a Biatch too.................. I'll bet it's got Ackerman problems...................
 it's made to go straight, has zero bump steer and not recommended for the street. didn't you read the entire sentence?
chryco
Checkout pics of early prostocks . The Motown Missile used a front K member very much like Bob`s . My original boxed unit is also very similar , also wasn`t for street use. Chryco
Checkout pics of early prostocks . The Motown Missile used a front K member very much like Bob`s . My original boxed unit is also very similar , also wasn`t for street use. Chryco   Here's a good article on bump steer for those who care: http://home.bresnan.net/~dazed/bump
i just read most of the article, well at least to the part they started to talk about mustang parts. getting bump steer out is a real pain in the a$$  but i was able to do it in just 2 weeks of working on it before i went to work at 1600hrs. well damn i did an immense amout of reseach on the subject before i installed the rack steering. when you all look at a picture it doesn't show all the angles to everything so in reality you can't make an intelligent comment on what it does or doesn't do until you put a toe gauge on it  and run it through it's full suspension travel. i even had a buddy come down and help with the toe gauge just to make sure my calculations were correct.  's rule the bottom balljoints are not turned around or switched side to side, i made a custom steering arm and just cut off the stock one next to the balljoint.  's still rule.
RaisinBran
Thanks for the article on bump steer! Hey Bob, do you have any pictures of the bottom of the k-member and/or pictures of the steering arms you made?
 10.71 @125
yes i do.
The only thing I have to say about this is if one of those kits (that looks cheesy IMHO) is 1200 dollars, you're almost halfway to an Alterktion.
I think Bob's is the way to go if you want to retain the K frame, but if you're going to bolt it on with those big ass brackets, I'd look for something else.
