Topic: 2'' carb spacer (Read 206 times)
1971scamp383
i have a torker aluminium intake on my 383 .030 over...stock forged crank polish and new bearing....edelbrock double roller timming chain...edelbrock torquer aluminium intake.....comp cams xe274.....edelbrock 750 cfm performer series....full length hedman headers 1 3/4 ..3'' out....440source aluminium heads(2.14 1.81 )....keith black dome pistons..(6cc dome)...10.1cr right now.....2500 torque stall(stall at 2900 rpm)...freshly rebuilt 727 with b&m transkit(shift kit)...3.91 rear gear with locker lock right ... i have a 2'' 4 hole phenolic carb spacer(new) hung on the wall.. ....is it makes a difference on the low torque?  ...cuz i know that my intake is not real good for torque down low....will this spacer help me a bit?  ? thanks....i dont really know how the car is going...i havent try it out yet with the new engine!!!
it should help. the 2" long holes should speed up the air/fuel mixture to help fill the cylinders.
I think you will have hood clearance issues as well ... i am using an eddy rpm on my chrysler 300 and had to get a drop base to use the air cleaner as it is.
67Dart383
We was having issues with tuning our Dart which has the torker intake on it, we installed a 2" open spacer and it really helped the tune!
67 Dart 383 MP590, Crane 1.6 R/R, headers, 906, 850 MIghty Demon, Performer RPM, 3inch exhausts, 727 R/M, 9.5 PTC 4500 flash stall w/ 2800 brake stall, 8 3/4 rear with P/T 4.30, on MT ET St Rad 11.77@112.97mph
