September 07, 2008, 04:02:19 AM
| | |-+  getting alignment...what specs?
Author Topic: getting alignment...what specs?  (Read 105 times)
west
« on: June 03, 2008, 11:59:05 PM »
assuming the tech doesn't have my 72 dart on his computer how should we set up the front end?
i figure 1/2 degree neg toe and as much caster as possible but what about camber?
ant suggestions?
this is mostly street driven,thanks.
                moparts can kiss my ass  moon
Re: getting alignment...what specs?
« Reply #1 on: June 04, 2008, 12:48:26 AM »
Setup ride height first. Then set max caster (front cam all the way out, rear cam all the way in). Bring the rear cam out until you have about .5 degree negative camber (maybe a little less, but keep as much caster as you can and keep the camber negative). Set the toe to 1/16" to 1/8" IN. Test drive. If it pulls adjust the camber slightly and accordingly.
