October 10, 2008, 10:04:39 PM
| | |-+  66 Dodge Polara rear end
Author Topic: 66 Dodge Polara rear end  (Read 238 times)
blasphemous
« on: June 04, 2008, 05:47:11 AM »
There's a Polara rear end for sale close by listed as a 8 3/4.  It's complete drum-drum, non-posi but the ratio isn't listed (waiting on a response).  I THINK the Polara is a C-body, but correct me if I'm wrong.  If so, there is no C-body 8 3/4 according to http://www.carnut.com/specs/frear.html
Can someone help clear this up?  I want to pick it up for the price if it is as advertised, or find out what it really is.
therocks
Re: 66 Dodge Polara rear end
« Reply #1 on: June 04, 2008, 08:24:26 AM »
If its a Polara its a C body in 66.Should be 6 3/4 rear.Probally a 2.76 or 2,90 gear ratio.We put a 69 Chrysler rear in my kids 62 300 when he installed the 4.10 gears.Then we out my spare 65 B body housing in because it was narrower.That rear will need cut down if you run it under a Dart.Rocky
jamesdart
« Reply #2 on: June 04, 2008, 03:45:15 PM »
i pulled an 8 3/4 out of a 66 polara and it had some funky 11x2" drums. i could not find brake stuff anywhere for that.
« Reply #3 on: June 04, 2008, 05:36:43 PM »
All 66 Polaras would have had an 8-3/4 rear end....................
blasphemous
« Reply #4 on: June 04, 2008, 11:23:33 PM »
What would you give for that rear end?  Asking price is $300
« Reply #5 on: June 04, 2008, 11:33:05 PM »
I sure wouldn't give $300 unless it had 11x2.5 brakes and axles that could be cut down to a-body size (some c-body rears are slightly too narrow and I suspect that's one of them). Even then I probably wouldn't give over $100............
blasphemous
« Reply #6 on: June 05, 2008, 12:43:24 AM »
I haven't bought my wheels yet, so I could get wheels to fit.
Quote
I don't know what you mean here though...?
« Reply #7 on: June 05, 2008, 01:08:25 AM »
There is no real value in the c-body rear end housing. There is some value in the third member and brakes. The axles have value if they are the type that can be cut down to a-body length and re-splined. They all taper to a smaller diameter before the splines and can only be shortened to the wider diameter. If the wider diameter is long enough they can be made into a-body big bolt axles.
therocks
« Reply #8 on: June 05, 2008, 11:15:45 PM »
Meant 8 3/4.My kid paid 75 bucks for the 69 rear.Of course that was like 4 years ago before scrap went nuts.It had almost new drums so we put them on the 65 rear to have the 11 inch beakes.He did run it for 1 1/2 years even with slicks it held up.Rocky
blasphemous
« Reply #9 on: June 06, 2008, 02:56:19 AM »
Looks like I'll be skipping that then.
I have a Ford 9" w/ 31 spline axles, but I don't have a center chunk for it.  I'll probably end up having that shortened and 8 3/4 ends put on it.
67Dart34dr0
« Reply #10 on: June 06, 2008, 11:49:23 PM »
8-3/4" till around '72, then 9-1/4", which can be modified to be used in a Dart.
The 11" drums are "cop drums", they are absolutely awesome at stopping from what I've heard. The 11"s are great upgrades for B-Bodies.
1967 Dodge Dart 270 4-door
'72 340 (9.5:1), '72 727 Torqueflite, '72 8-3/4" Rear, '73-'76 Big Bolt Discs, Repaints, Original Interior, Possibly Original Miles, stock '72 valves, Factory A/C
