Topic: 66 Dodge Polara rear end (Read 269 times)
blasphemous
There's a Polara rear end for sale close by listed as a 8 3/4. It's complete drum-drum, non-posi but the ratio isn't listed (waiting on a response). I THINK the Polara is a C-body, but correct me if I'm wrong. If so, there is no C-body 8 3/4 according to http://www.carnut.com/specs/frear.htmlCan someone help clear this up? I want to pick it up for the price if it is as advertised, or find out what it really is.
therocks
If its a Polara its a C body in 66.Should be 6 3/4 rear.Probally a 2.76 or 2,90 gear ratio.We put a 69 Chrysler rear in my kids 62 300 when he installed the 4.10 gears.Then we out my spare 65 B body housing in because it was narrower.That rear will need cut down if you run it under a Dart.Rocky
i pulled an 8 3/4 out of a 66 polara and it had some funky 11x2" drums. i could not find brake stuff anywhere for that.
All 66 Polaras would have had an 8-3/4 rear end....................
blasphemous
What would you give for that rear end? Asking price is $300
I sure wouldn't give $300 unless it had 11x2.5 brakes and axles that could be cut down to a-body size (some c-body rears are slightly too narrow and I suspect that's one of them). Even then I probably wouldn't give over $100............
blasphemous
I haven't bought my wheels yet, so I could get wheels to fit. axles that could be cut down to a-body size (some c-body rears are slightly too narrow and I suspect that's one of them). I don't know what you mean here though...?
There is no real value in the c-body rear end housing. There is some value in the third member and brakes. The axles have value if they are the type that can be cut down to a-body length and re-splined. They all taper to a smaller diameter before the splines and can only be shortened to the wider diameter. If the wider diameter is long enough they can be made into a-body big bolt axles.
therocks
Meant 8 3/4.My kid paid 75 bucks for the 69 rear.Of course that was like 4 years ago before scrap went nuts.It had almost new drums so we put them on the 65 rear to have the 11 inch beakes.He did run it for 1 1/2 years even with slicks it held up.Rocky
blasphemous
Looks like I'll be skipping that then. I have a Ford 9" w/ 31 spline axles, but I don't have a center chunk for it. I'll probably end up having that shortened and 8 3/4 ends put on it.
67Dart34dr0
8-3/4" till around '72, then 9-1/4", which can be modified to be used in a Dart.
The 11" drums are "cop drums", they are absolutely awesome at stopping from what I've heard. The 11"s are great upgrades for B-Bodies.
