Topic: Gauge light wiring (Read 142 times)
Bigcube
I would like to wire the lights for my gauges to come on with the parking lights. Anyone know how to tap into the factory wring under the dash to do that? It's a 69 dart, all the factory wiring is there. Thanks
Jim  Yes it's fast and no you can't drive it! Best 1/8 1.259 60', 5.67@121 Best 1/4 8.94@151 All Motor http://www.bigcube.org/
SIKPUP
If you can get your headlight switch out where you can see it , Check for the wire that becomes hot for your parking lights when you pull them on. Tap into that one....ground anywhere that you have metal left.... SIKPUP
 Spring City, Pa.
thebankerstoy
Hi Jim. If you would like, I could e-mail you the wiring diagrams for your car if that would help you out. Just let me know what e-mail address you want me to send them to.  Richard
Bigcube
Richard, that will probably help. I noticed all the terminals on the head light switch are letter coded. One terminal was labeled "D" I wonder if that is "dash"  My email is bigcube@stny.rr.com Thanks!
thebankerstoy
Richard, that will probably help. I noticed all the terminals on the head light switch are letter coded. One terminal was labeled "D" I wonder if that is "dash"  My email is bigcube@stny.rr.com Thanks! Hi Jim, I'm not sure about the wiring on the 69 Dart's, as I've never worked on one, but the wiring for the gauges should all be orange in color if it's like the other various Mopars I've worked on. The wiring diagrams should answer all of your questions though. I'm going to sign off here on B.B.D. and send you the diagrams, so you should have them in a couple of minutes. I'll sign back on here afterwards and see if they came through to you ok? Richard
Bigcube
Well I'm at work, I'll send you a reply email when I got home. Thanks!
thebankerstoy
cool Jim, By the way, all work and no play makes Jim an unhappy man!  Richard
the black wire on the headlight switch is the one you want ...
Bigcube
the black wire on the headlight switch is the one you want ...  Sweet! That is the info I was was looking for.  The new door panels were on my door step today. I really need to get busy.. Interior is out, front glass it out, dash it out, motor and tranny is out
Bigcube
Richard, you are also correct, according to the diagrams you sent, the orange wire on the cluster plugs are also the instrument lights
