December 05, 2008, 01:50:51 AM
| | |-+  Let me tell you guys what someone did .This will kill you
Author Topic: Let me tell you guys what someone did .This will kill you  (Read 532 times)
sperrydan
I live for Mopar and my Ruth
« on: June 05, 2008, 04:27:50 AM »
Ok i knew that i had some rust in the iner rocker just behind the wheel wells and my q panels need to go as well so i cut the Q panel off and i find House insulation expanding foam in the hole in the inner rocker behind the Qs and this stuff has made the iner iner rocker to the floor rot. Its just a 8 inch spot but come on this is killing me that someone would do this. Now i have to spend the time to fix this. so i have to fix rot on the bottom of the wheel well and the iner side of the iner rocker and the outside of the iner rocker. Its all looks farely easy but time consuming. Has anyone had rust in this spot or am i the lucky one. Frustrated
Re: Let me tell you guys what someone did .This will kill you
« Reply #1 on: June 05, 2008, 10:49:35 AM »
I'm sure that foam was somebody's attempt at resculpting where there was already rust-through.
sperrydan
« Reply #2 on: June 05, 2008, 01:23:51 PM »
It wasnt resculpting BC it was behind the Q. the hole was maybe quarter size hole on the very bottom side of the Q panels .It was to plug the hole. I should take a pic to better show you
Im starting to laugh about it now. I was mad BC it was more work for me but now  throw money
67 dartgts
Go fast or go Home
« Reply #3 on: June 05, 2008, 02:04:45 PM »
Hello:
Yeah like jim said just an attempt at quick fix...i've seen them shot full of stryfoam and puttyed over...makes you just wanna choke someone.  cat fight
     Maynard
« Reply #4 on: June 06, 2008, 12:36:15 AM »
i have seen chicken wire and concrete.
Arillious
BAM!
« Reply #5 on: June 06, 2008, 01:13:22 AM »
concrete??
Tiamat
« Reply #6 on: June 06, 2008, 03:14:09 AM »
Best one I saw was a chassis rail with one side made with aluminium tape and then underseal to disguise it. you could poke holes in it with your finger  \/][
« Reply #7 on: June 06, 2008, 03:25:55 AM »
Funny.....there was a thread asking about where to buy that stuff on here just other day.
http://www.bigblockdart.com/index.php/topic,29777.msg288714.html#msg288714
« Reply #8 on: June 06, 2008, 06:46:10 AM »
i found a quarter panel patch made out of a diaper once...lol...beer cases are common quarter replacement panels also lol
4spdfury
« Reply #9 on: June 07, 2008, 01:34:00 AM »
someone had cut the wheel well opening out on my car and had brazed 3/4 round copper tubing and coverd it with bondo to fix it.
satellite65
« Reply #10 on: June 07, 2008, 09:10:25 AM »
Hey, at least the guy had the common sense to use some kind of metal. I knew a guy who used balled up newspapers, covered it with bondo, and used waxed paper to smooth the bondo while it dried. Quality work.
VTI
NHRADART@msn.com
« Reply #11 on: June 07, 2008, 02:42:48 PM »
On my first barracuda, some one used plastic edging and then feathered the bondo out. The screws were still sticking through the inside of quarter panel. Surrprised they didnt slice up the tires.
MoparManicMechanic
« Reply #12 on: June 07, 2008, 03:53:07 PM »
I went to a body shop for an estimate on some trunk work and he showed me where someone had put a "Dish Scouring Pad" to fill a dent in a door on some other customers car and then bondoed over that!  lol
WildCat
"Do It Again"
« Reply #13 on: June 08, 2008, 12:49:38 AM »
I went and looked at a car that had "great stuff" in it, he said he had an exhaust leak into the interior and thought it would help stop it
good luck on getting it fixed
