December 05, 2008, 01:57:02 AM
| | |-+  steel wheels or aluminum...any difference in the quarter mile.....
Author Topic: steel wheels or aluminum...any difference in the quarter mile.....  (Read 1083 times)
warthog
« on: June 05, 2008, 08:10:30 PM »
I have a set of weld wheels on my 67 Dart GT right now.  I am needing to get a set of 15x10 with 7.5 backspacing for my rear minitubbs.  Anyways, I keep toying with the idea of putting on the poverty caps and steel wheels on my dart and thought about having a set of 15in custom offsetted with the 7.5 backspacing for the rear so I can run the poverty caps.   I get bored with seeing the weld wheels on everything although I do like them on my car.  I was wondering if any of you guys have tried both in the quarter and if aluminum wheels made a difference in et's over steel wheels?
Re: steel wheels or aluminum...any difference in the quarter mile.....
« Reply #1 on: June 05, 2008, 09:45:42 PM »
Less weight = faster times....
DJVCuda
« Reply #2 on: June 06, 2008, 06:24:11 AM »
back to back on a small block a-body is about a 10th.
thats 15" ralleys to aluminum skinneys up front and the same size out back.
Blue
« Reply #3 on: June 09, 2008, 01:35:32 PM »
One of the magazines did this very test, they saved a bunch of rotational weight and expected to see the car run a lot quicker, it didn't Dunno
Arillious
BAM!
« Reply #4 on: June 10, 2008, 12:26:54 AM »
One of the magazines did this very test, they saved a bunch of rotational weight and expected to see the car run quicker, it didn't Dunno
yea i remember that wasn't that an article in an issue of hotrod magazine? if you go to their website you may be able to find the article. thats where i read it i think.
Blue
« Reply #5 on: June 10, 2008, 09:33:52 AM »
Might have been Hot Rod, I don't think it was one of the Mopar magazines.....
Found it, it was Car Craft, here ya go....
http://www.carcraft.com/projectbuild/116_9905_light_vs_heavy_wheels_comparison/photo_06.html
Womanator
Womanator Racing
« Reply #6 on: June 10, 2008, 11:32:44 AM »
There's as certain mph that you can't have hub caps on your car because of them coming off  during the run in the 1/4 mile.Might want check the rule book.
« Reply #7 on: June 14, 2008, 05:16:32 PM »
  Remember you're dealing with "un sprung" weight. Having all four lite weight wheels only effects the over-all weight of the whole car. There would be minimal difference in performance, if any, I think. Having steel wheels in the front I believe would be counter productive as you want the suspension to rise in the front and lifting steel wheels is going to be harder, i.e. more weight. In the rear, who cares! You want weight in the rear or over the rear tires; you're not trying to lift those. Or your not supposed to be; if you are, you have other suspension issues (squatting) that needs addressing.
  I run Centerlines in the front, skinnies, and steel out back 15x10 cop car wheels with slicks. Mainly because I'm cheap and I had them on hand. Too much of this  throw money can get you this  madwife. See, it is also a self preservation thing too.  Grin
ksdartguy
« Reply #8 on: June 18, 2008, 09:07:54 AM »
I ran 123mph last year with my dog dish's and didnt lose them.
I did go weld"s this year. (traded some stuff I wasnt using for them)
I went with the Jegs knock off on the front.
mshred
« Reply #9 on: November 10, 2008, 07:19:42 PM »
Did the aluminum wheels knock anything off your time? did you notice a difference at all?
A13Dart
Minnesota
« Reply #10 on: November 10, 2008, 08:43:12 PM »
Some say that rear steel wheels help reduce wheel spin in poor traction conditions.  It's a theory.  Dunno
mshred
« Reply #11 on: November 10, 2008, 09:27:30 PM »
sounds like it makes sense....but what im really concerned with is performance difference between the two
73swinger
Blackstock, Ontario
« Reply #12 on: November 10, 2008, 11:06:49 PM »
I love the look of steelies
375InStroke
« Reply #13 on: November 11, 2008, 10:24:28 AM »
Why minimal difference in performance?  For handling, the less unstrung weight, the better.  For acceleration, the engine has to accelerate the vehicle forward, but it also has to accelerate the wheels rotationally.  The weight of the front wheels has no affect on weight transfer.  The front of the car rises, but the wheels stay on the ground.
375InStroke
« Reply #14 on: November 11, 2008, 10:28:55 AM »
In the ricer and truck world, when people put bigger wheels, like 20" and 22" rims, the car usually accelerates slower and stops slower due to the weight all out in the rim.
Brad4406
« Reply #15 on: November 11, 2008, 12:33:36 PM »
Not to be rude or disagree with you, but if they didn't change their gear ratios and are now running a larger over all tire diameter, their slower accelleration is not due to weight or more mass, it is due to the larger over all tire diameter changing their gear ratio.  For example, with 27" tires on my truck w/ a 4.10 ratio it will accellerate faster than w/ 35" tires and the same ratio.
Brad4406
brawn4406@yahoo.com
mshred
« Reply #16 on: November 11, 2008, 06:14:21 PM »
so pretty much the wheels won affect time? in the carcraft test they took a second off the car from switching from steelies to aluminum...? what do you guys think
67Satty
« Reply #17 on: November 11, 2008, 07:43:53 PM »
It's only worth about a tenth of a second from the heaviest 15X7 steel wheel to the lightest 15X4 aluminum wheel according to the Car Craft test.  So it's just personal preference whether or not you need every last tenth of a second versus the handling versus whatever look you prefer.
I think the aluminum skinnies look pretty cool but I've experienced them plowing in turns on the street where I wasn't even going very fast.
Car Craft Test Configurations
Test 1
(2) 15x7 rally with BFG P215/60R15 = 95.56 lbs.
(2) 15x8 rally with M/T 26x10.5-15 = 93.70 lbs.
Total weight = 189.26 lbs
e.t. and mph = 12.137@111.99
Test 2
(2) 15x4 rally with M/T 26x7.5-15 = 70.86 lbs.
Total weight = 164.56 lbs.
e.t. and mph = 12.107@112.52
Test 3
(2) 15x7 Center Line with BFG P215/60R15 = 70.46 lbs.
(2) 15x8 Center Line with M/T 26x10.5-15 = 64.10 lbs.
(4) Center Line center caps = 0.96 lb.
Total weight = 135.52 lbs.
e.t. and mph = 12.103@112.10
Test 4
(2) 15x4 Center Line with M/T 26x4.5-15 = 42.12 lbs.
(2) 15x8 Center Line with M/T 26x10.5-15 = 64.1 lbs.
Total weight = 107.18 lbs.
e.t. and mph = 12.026@113.11
In the garage:  '67 Plymouth Satellite - once my 318-powered daily driver, now my project car with lots of "patina"
On the stand:  "Old School" '71 440 build:  "6 Pack" pistons at zero deck, Engle .534, 238@.050" Hyd, stock 452s, Performer RPM, 850 DP, Hooker headers.  Still need: ignition, gears
chryco
« Reply #18 on: November 12, 2008, 07:39:24 AM »
Good enough for these guys , good enough for me !
A13Dart
Minnesota
« Reply #19 on: November 12, 2008, 09:47:37 PM »
Whatever gets the job done.
moparteacher
« Reply #20 on: November 13, 2008, 01:21:18 AM »
In the Car Craft article they just reduced weight via wheels and tires. I'd like to see if rotational mass of the wheel makes a noticeable difference in et with the vehicles total weight being the same.
Moparteacher
chryco
« Reply #21 on: November 13, 2008, 08:26:10 AM »
Take a steel 15x12" wheel and lift it over your head 10 times , next do the same with a 15x12" alloy wheel . Take a deep breath and think . Notice any difference ?
Basic Physics : lighter is better for acceleration .
  If it walks like a duck and quacks like a duck ............it`s a duck
Go Alloy wheels .
mshred
« Reply #22 on: November 13, 2008, 09:22:07 AM »
Go Alloy wheels .
i think your right about that lol bash alloys it will be for me
coors00
« Reply #23 on: November 13, 2008, 05:51:51 PM »
Just a thought; instead of lifting them, roll them on the floor.
chryco
« Reply #24 on: November 14, 2008, 04:50:21 PM »
Yes , and  measure the amount of force required to push the alloy wheel as opposed to the steel wheel .
coors00
« Reply #25 on: November 14, 2008, 06:00:27 PM »
Which seems to equal i/10 et.
coors00
« Reply #26 on: November 14, 2008, 06:05:26 PM »
Hey Chryco, no disrespect, it just seems to be worth 1/10. If I can use the wheel money for other improvements, I think I can get more for my money. Just a thought.
chryco
« Reply #27 on: November 14, 2008, 07:39:10 PM »
None taken Bro ! Just remember,  all those tenths add up .
coors00
« Reply #28 on: November 14, 2008, 08:48:07 PM »
Wink
Us newbies still think about 1 seconds, or 1/2 seconds. We aint up to your area yet.
I always that that alloy rims made more difference. Now I can get cheap steelies made, to use, while sorting an untested car out.
chryco
« Reply #29 on: November 14, 2008, 09:06:22 PM »
Wink
Go for it ! I did that 30 years ago , now I have alloy wheels.
Pages: [1] 2  All Go Up Print
