December 05, 2008, 12:17:57 PM
| | |-+  toe problems on 69 Dart
Author Topic: toe problems on 69 Dart  (Read 336 times)
gt
« on: June 06, 2008, 01:42:42 PM »
Hello.
I am having problems setting the toe on my 69 Dart.
It had power steering originally with the 273. It now has manual with the 440. It also has the front disc brake conversion from 73 up A body with Bills tubular upper arms.
On the drivers side the tie rod sleeve is turned all the way out (if I go any farther the clamps will not secure the sleeve to the tie rod end), and the passengers side is turned all the way in, but the toe setting is still out.
I started by centering the steering box and steering wheel, and then tried to adjust the toe, and that is when I came upon this problem.
Any help here would be greatly appreciated.
gt
Re: toe problems on 69 Dart
« Reply #1 on: June 06, 2008, 01:49:28 PM »
gt
« Reply #2 on: June 06, 2008, 01:56:40 PM »
Thats funny, but does not help me any.
gt
« Reply #3 on: June 06, 2008, 02:25:40 PM »
Sorry.   Just figured I'd throw confusion into an already tense situation.
ValiantOne
Western MD
« Reply #4 on: June 06, 2008, 03:16:14 PM »
sounds to me like something had been reversed, or assembled incorrectly. UCA's should't really be causing it.
I'd pop the tie rod ends out of the knuckles, dissassemble the sleevs and inner tie rods. Make sure everything is threaded in the correct direction. Center the wheel again. center the front wheels and put it all back together.
CE
Chris Evrard
-76 Cordoba, 360 4bbl
-68 Valiant, 273 2bbl
dartracer
Strasburg CO.
« Reply #5 on: June 06, 2008, 06:34:10 PM »
Pics would help, but sounds like your pitman arm needs to be moved.
gt
« Reply #6 on: June 06, 2008, 11:14:26 PM »
Strange how things work out. I went out and got a new pitman arm for the 69, Moog K7074. It looked exactly like the one on the car but tried it anyways. Installed it, centered the box, centered the steering wheel, centered the front wheels and hooked it up. It was pretty close, so good enough until I take it for a front end alignment. So I reinstalled my old pitman and all seems good. Hopefully next Friday I can get it on an alignment rack and will return the new pitman arm.
Thanks for you help.
gt
« Reply #7 on: June 07, 2008, 01:35:04 AM »
You were likely one turn off on the steering gear. At center the idler and pitman arms should be parallel to the frame rails.
« Reply #8 on: June 07, 2008, 09:41:01 AM »
u need to use a left and right handed thread tierod end so that adjustment screws both ends in or out...not 1 in and 1 out
gt
« Reply #9 on: June 07, 2008, 10:46:33 AM »
Its impossible to install the tie rod ends incorrectly as the sleeve is right hand on one side and left hand on the other side, it works like a turn-buckle.
Jim that is what I wanted to know, about the position of the pitman arm and the idler arm in the straight ahead position.
All seems ok now, hopefully next week I can get it to the alignment shop. I am soooo close to having this bbd sign on the road.
Thanks to all for the replies.
gt
« Reply #10 on: June 07, 2008, 10:51:22 AM »
ok...gotcha now...thought u were saying 1 end all in and 1 end all out on the same sleeve Lips Sealed
gt
« Reply #11 on: June 14, 2008, 07:15:14 PM »
got the Dart aligned yesterday.
All is good now  !nanr
Hopefully in a couple of weeks it will be licensed and insured and on the road.  !nanr !nanr !nanr
gt
