August 28, 2008, 04:31:53 PM
|-+  General Category
| |-+  Off-Topic
| | |-+  12 Broken teeth - ring gear!!
Author Topic: 12 Broken teeth - ring gear!!  (Read 251 times)
Dartsport
« on: June 06, 2008, 07:25:54 PM »
While I was changing the oil and filters in the motor and tranny, rear end fluid , and checking everything over. I found 12 broken teeth on the ring gear. I haven't had any noise from the rear end. When I went to put the drain plug back in the rear, I saw something laying across the drain plug hole.  I grabbed a small magnet, and found out the bad news.
      So I pulled the center section out. 12 chipped teeth. So I installed my extra center section. It is always something!!  throw money  throw money
lowtek32
Re: 12 Broken teeth - ring gear!!
« Reply #1 on: June 06, 2008, 08:31:22 PM »
"checking everything over"           saved big problems later.               Maybe something made you
      "suspicious"  Huh
                                         Dunno
Central PA
Newbomb_Turk
Archbald, PA
« Reply #2 on: June 06, 2008, 09:39:23 PM »
And you were running it like that?? WOW!! Shocked Shocked Shocked
MY BIG BLOCK DEMON 493 AND ALMOST READY TO GO!!
chryco
« Reply #3 on: June 06, 2008, 11:46:25 PM »
Sorry to hear of the broken parts , BUT,  if it`s going to bust , at least it was still in the shop !
  Here`s to a speedy repair !
    Chryco Wink
P.S. Reminds me of when I broke my front ladderbar rod end , pushing the car from the garage to the trailer !
Hemi Darts Rule !!!!!
evstraus
« Reply #4 on: June 06, 2008, 11:54:18 PM »
I've got to ask, what's the brand of the ring and pinion? Also, what causes something like this to happen? Eric  4 speed
MVRCorp
« Reply #5 on: June 07, 2008, 12:00:55 AM »
Sounds like you dodged a bullet.  Grin
It could have been alot worst.  explode
Dartsport
« Reply #6 on: June 07, 2008, 06:41:41 AM »
  I don't remember what brand the gears are??  I would have to dig up the receipts from 2 winters ago.  The cause of the breakage is probably, Trans brake, and 32" x13.5" x 15" Hoosier slicks, 1.28 to 1.32  60' times.
damopars
VA
« Reply #7 on: June 07, 2008, 07:46:06 AM »
Good thing you caught it in the shop.  duster
Dave
chryco
« Reply #8 on: June 07, 2008, 08:04:21 AM »
The gear set must be pro gears , they more brittle . Dana maybe ? Bigger = stronger ?
Keep us posted , I`m very interested . 557 Cu.In / 750 ft.lbs / trans brake /14.5 x32x15`s.
  Chryco Wink
jamesdart
« Reply #9 on: June 07, 2008, 08:42:55 AM »
i was under the impression it was pretty common when running a transbrake. a guy i know had some one running his car for a while, the guy wanted to race and was a good driver but didnt have a car. my  friend wanted his name out there so he let him run the car for a while. the guy didnt maintain anything or check anything, a few teeth let loose at a shift point, i think into 3rd, the tires locked up, the car rolled several times and beat the hell out of the body.
Dartsport
« Reply #10 on: June 07, 2008, 05:11:26 PM »
  Chryco Wink
  The gears were street gears. The 4.10 gears that broke, had 205 runs on them. They look to be set up , a little to far out on the ring gear.   I installed my 4.30 gears that have a little over 300 runs on them. The pattern on the gears are centered more on the gears.  I will redo the broken set, so I have a spare again!!
golferjohn
« Reply #11 on: June 07, 2008, 08:46:58 PM »
ouch!!
Pedalkisses
A proud and ugly American on the inside!
« Reply #12 on: June 07, 2008, 08:52:51 PM »
I think those gears need dentures! Dunno
bigtimeauto
Plymouth meeting, PA
« Reply #13 on: June 07, 2008, 09:42:52 PM »
Pro gears have more nickel in them making them softer and wear like crazy.
Looks to me like the pinion was not in the mesh deep enough or there was to much backlash.
Bob
www.bigtimeauto.com
Procharger dealer
NOS refills
Allentown, PA
« Reply #14 on: June 07, 2008, 09:46:04 PM »
Looks like it's time for a dana ...
