Topic: Header options with my set up... (Read 414 times)
zpsull01
Well I'm trying to get the exhaust lined out for my '72 Duster with a 440 and t-56. My question is do I have any other options as for headers since I running an AlterKtion? I have also removed the shock towers and filled that in. It just seems like I'll have more room to possibly use something else. I want at least a 1 3/4" primary underchassis header. I thought about trying to pick up a cheap set of B-body headers and seeing what I can do with them. I wouldn't mind taking a cheap set and having to reroute a few tubes but I wouldn't want to do it to a better set. Any insight or ideas would be much appreciated.
Thanks, Zack
If I read that correctly you have a 440 a body with a manual trans and an alterkation ? if so any b body header should fit ... might have to do a few small mods for the clutch linkage unless you are doing a hydraulic throwout then any header should fit ..
ksdartguy
zpsull01
Yea that's correct. I am using a hydraulic throwout also so this will allow me to use about anything for a B-body? And the Pro-parts 2" are partial fenderwell correct?
Bill_Reilly
B headers are jammed against the passenger inner - if you removed that, it will work. On the driver side, the #7 tube almost always goes right through the steering column - you have no choice but to re-route that one tube. Otherwise, they should work.
ksdartguy
And the Pro-parts 2" are partial fenderwell correct? I believe 1 tube on 1 side and 2 on the other go outside the frame. Im looking at those for my stroker B motor,
zpsull01
Bill, when you said the inner fender were you talking about the whole thing? I just cut out the shock towers and filled them in with a piece of metal. Would this work?
And I'm little worried about the fenderwells with tire clearance. I am running a 17x8" rim up front with like 5.625" backspacing and I'm wanting to run about a 25.5-26" tall tire thats about 9" wide. And since this is mostly a street car it worries me a little with the clearance issues.
gearhead01
If you don't fail, you cannot succeed.
ari440:
Are you running an exhaust system under the car, or is it race only?
I am assuming you ave a 727, transmission. Is there adequat room for a transmission shield, or is it too close so you have to run a trans blanket?
Thanks
John
1968 Plymouth Valiant 2-Door Post Bracket Car In Progress 1971 Plymouth Satellite Sebring Plus, 383, Auto 14.46 @ 94.53 MPH
ari440
hi JOHN
for the street 3.5 pipe 3 chamber flowmasters
I have a 727 trannie and csr sheild
its a nigthmare to put on !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
four top bolts too long
need to hammer back the lip ........ firewall to chassie
the hump on the sheid hits the chassie need to hammet it up or the cross member will not fit
the strap is in a bad spot .... had a hard time with it
need to cut off the ears off the trannie
but with the sheild you dont need a converter shild if you used the blanket
gearhead01
Thanks ari440.
First of all, beautiful car. How fast are you running.
I want to go with the trans shield. I am not too sure how well a blanket will work on the street. Back to the original question, do the ProParts headers give you any problems with the tranny shield?
Thanks again.
ari440
thank you JOHN
511 ci 650/292 solid cam indy sr,s m/w port 1050 dom
5000 stall 4.10 gears 29.5 10.5 15 mt,s slicks
1.45 ft 10.20s 131 mph 3470 pounds
the proparts collecters come off when you drop a trannie down , so there easy to work with
the strap is in a bad spot if they moved it 2 inch down from where it is it would be easy to do
CSR designed it but not when its in the car................. its a pain to deal with
jackie
ari440, very nice car.. clean.. good job..
