Topic: front of leaf spring bolt size. (Read 413 times)
4spdfury
was wondering if some one could tell me the size of the bolt that goes through the front of the leaf spring. my car was a /6 3spd car. got the spring buckets on order and he needs to know what size to drill the holes. im not going to be around my car until wendsday, would like to get him an answer sooner than that if at all possible
robx4406
Factory A body stuff is usually 1/2"
Others (B&E) are 5/8"
smallbigblock
My 67 Dart had 5/8" bolts
I should have left it alone
mattsmopars
 My 67 dart was 5/8'' as well. Slant 6 - auto from the factory. Hope this helps you. Matt
MoPar_or _NoCar
5/8" til 70' then 1/2".
BrianT
It's 1978 all over again!!
I hate to beat a dead horse, but I'm getting ready to order the relocation kit from thecarfarm and I need to know what size bolts I have, but the car is 20 miles away.
My car is a 67 Dart originally slant 6 auto. From what I'm reading it could be either 1/2 or 5/8 inch. But the post above makes it sound like they were all 5/8 inch. Help!
 67 Dart 340 "Doing everything ass backwards"
my 69 had 1/2", my 67 had 5/8, both were slant 6 auto cars.
That One Guy
from the posts, the 67 would have had a 5/8"
"I'm your Huckelberry"
coors00
Have it drilled 1/2; A 5/8 bit is only $15
BrianT
It was 5/8 and the relocation kit has been purchased from thecarfarm
Arillious
i drilled mine 5/8's but thats because i went with "super stock leaf springs". my 68 dart had a smaller bolt for the front hanger but since i changed the springs i had to drill for a bigger size which turned out to be 5/8. so was smaller and now is 5/8. thats just my two cents cant remember the size of the original bolt. if you absolutely cant frigure out the size get the kit with the smaller bolt hole then just drill them bigger (if you have to) should be no biggie
