December 03, 2008, 03:27:46 AM
| | |-+  Need flywheel #
Author Topic: Need flywheel #  (Read 95 times)
Womanator
Womanator Racing
Need flywheel #
« on: June 09, 2008, 01:33:30 AM »
Starting a new project.I'm thinking about putting a 4-speed in a 74 scamp but need to know which flywheel I'llneed to put the 4-speed behind a internally balanced 383 or 440.Any help would be great.
robx4406
Re: Need flywheel #
« Reply #1 on: June 09, 2008, 12:09:46 PM »
Assuming a 6 bolt crank, any 130 tooth, internally/neutral balanced flywheel will work.
Womanator
Womanator Racing
Re: Need flywheel #
« Reply #2 on: June 09, 2008, 01:20:09 PM »
Thx I've just not done a 4-speed car in years.
MoPar_or _NoCar
Re: Need flywheel #
« Reply #3 on: June 09, 2008, 02:39:21 PM »
moparteacher
Re: Need flywheel #
« Reply #4 on: June 09, 2008, 03:14:17 PM »
Remember if you are running a stock bellhousing then you will need to match the flywheel with the bellhousing. The 10.5 and 10.95 130 tooth flywheels require a different bellhoousing than an 11 inch 143 tooth flywheel.
The lakewood scattershield can use either flywheel.
Mcleod has aluminum flywheels on clearance for $200. on e-bay.
Moparteacher
