October 10, 2008, 10:10:24 PM
| | |-+  Fuel Cell
Author Topic: Fuel Cell  (Read 397 times)
MOPARTOYA
Fuel Cell
« on: June 10, 2008, 11:08:49 AM »
Need education on Fuel Cell. Looking at a 20 Gal. When would a fuel return line be used? Old stock tang will not fit due to coil overs.
ths,
Randy Huh
68 Valiant getting the RB treatment.
mopwr2004a
Re: Fuel Cell
« Reply #1 on: June 10, 2008, 11:46:03 AM »
the only fuel system that really needs a return is a EFI system or if you are using one of the big fuel pumps that have the bypass right next to the pump like the Magnafuel 500 or the BG400.  however you can run a return on any fuel system if you want to. it does help the life of the electric pumps and cools the fuel going thru the pump by circulating it. hope this helps
MOPARTOYA
Re: Fuel Cell
« Reply #2 on: June 10, 2008, 04:59:51 PM »
Yes That was most helpful mopwr2004. I can just plug that feature for now. motorinstall
VTI
NHRADART@msn.com
Re: Fuel Cell
« Reply #3 on: June 13, 2008, 08:25:48 PM »
On your fuel cell, Are you going to use  an aluminum one or a plastic one? Just curious to wich one is better?
Re: Fuel Cell
« Reply #4 on: June 14, 2008, 04:59:57 PM »
Don't forget to have a breather. Without it you could have teh pump sucking the tank into a vacuum and starving the system of fuel becasue of it. I used the return point in the tank for that purpose (see pic). What you can't see in the pic is the hose turning into metal line that is coiled about three turns upwards and then turned towards the floor and through it. This allows the fuel to wander and slosh as much as it likes without the ability to escape to the ground even of the car is upside down.
MOPARTOYA
Re: Fuel Cell
« Reply #5 on: June 15, 2008, 09:45:05 AM »
I was planning on a Alum. over plastic type from RCI. Car will mostly see street. Also has provitions for venting.
Ths.
