October 12, 2008, 05:28:21 AM
| | |-+  Small bolt disc brake rotors
Author Topic: Small bolt disc brake rotors  (Read 305 times)
72 440 modart
« on: June 10, 2008, 04:11:42 PM »
Can anybody tell me what the minimum thickness is for small bolt rotors they came off a 72 dart. What is the thickness when they are new
the number I've seen is 810 is this new or minimum
thanks mike
Re: Small bolt disc brake rotors
« Reply #1 on: June 10, 2008, 04:21:04 PM »
The 67 FSM does not list a minimum, just a dimension of .810. It does show a minimum thickness for the b-body rotor. This might indicate that they did not recommend turning the K-H rotor, but the manual does not mention this.
72 440 modart
« Reply #2 on: June 10, 2008, 09:21:04 PM »
Does that mean you can't turn the K-H rotors. I'm looking at a setup with rotors that measure 776 and 775. That still seems fairly thick to me
« Reply #3 on: June 11, 2008, 12:36:15 AM »
Like I said the manual doesn't address it. I don't remember if the rotors have a min. thickness cast into them, but I've got a few sets I could look at. I'd probably run those, but not turn them again. What I've been doing for a few years now is to bead blast the rotors if they aren't warped or grooved. This gives a nice surface without removing any metal. I'm planning on installing one of my sets on my GTS, but I've got some new rotors in the garage for that.
« Reply #4 on: June 11, 2008, 12:46:06 AM »
I just checked a couple of other manuals. They state to replace the disc if runout is excessive. None give a minimum thickness, again indicating that .810 is as delivered and min.
67Dart34dr0
« Reply #5 on: June 11, 2008, 08:08:15 PM »
Rotors are available new 15/ea, spindles are the really hard part. Hub is not included, so if you can get that as well you should be okay, I'd think.
1967 Dodge Dart 270 4-door
'72 340 (9.5:1), '72 727 Torqueflite, '72 8-3/4" Rear, '73-'76 Big Bolt Discs, Repaints, Original Interior, Possibly Original Miles, stock '72 valves, Factory A/C
« Reply #6 on: June 11, 2008, 08:32:03 PM »
$15/each. WHERE?
67Dart34dr0
« Reply #7 on: June 11, 2008, 08:42:40 PM »
I coulda swore my 7 was between them.  lol $175/ea.
mopardart71
« Reply #8 on: June 26, 2008, 09:20:39 PM »
$15,the cheapest ive seen is $125  each!!!
