Topic: Small bolt disc brake rotors (Read 290 times)
72 440 modart
Can anybody tell me what the minimum thickness is for small bolt rotors they came off a 72 dart. What is the thickness when they are new the number I've seen is 810 is this new or minimum thanks mike
The 67 FSM does not list a minimum, just a dimension of .810. It does show a minimum thickness for the b-body rotor. This might indicate that they did not recommend turning the K-H rotor, but the manual does not mention this.
72 440 modart
Does that mean you can't turn the K-H rotors. I'm looking at a setup with rotors that measure 776 and 775. That still seems fairly thick to me
Like I said the manual doesn't address it. I don't remember if the rotors have a min. thickness cast into them, but I've got a few sets I could look at. I'd probably run those, but not turn them again. What I've been doing for a few years now is to bead blast the rotors if they aren't warped or grooved. This gives a nice surface without removing any metal. I'm planning on installing one of my sets on my GTS, but I've got some new rotors in the garage for that.
I just checked a couple of other manuals. They state to replace the disc if runout is excessive. None give a minimum thickness, again indicating that .810 is as delivered and min.
67Dart34dr0
Rotors are available new 15/ea, spindles are the really hard part. Hub is not included, so if you can get that as well you should be okay, I'd think.
$15/each. WHERE?
67Dart34dr0
I coulda swore my 7 was between them.  $175/ea.
mopardart71
$15,the cheapest ive seen is $125 each!!!
