Welcome,
. Please
login
or
register
October 06, 2008, 09:48:01 AM
1 Hour
1 Day
1 Week
1 Month
Forever
The BigBlockDart Message Board
Technical
Chassis, Suspension
large bolt disc brake conversion
Pages:
1
Topic: large bolt disc brake conversion (Read 222 times)
72 440 modart
on:
June 12, 2008, 02:00:09 PM »
when you use spindles from a "M" body can you use the rotors and calipers from these cars or do you have to use the 73-76 "A" body
rotors and calipers. Also are the lower balljoints different between A and M body
thanks
kawazuki8097
New Cumberland PA
Re: large bolt disc brake conversion
Reply #1 on:
June 12, 2008, 02:35:47 PM »
Everything between the LCA and the UCA should go on as-is.
Yep - F/M/J LBJ's are diff than A. You will need diff bolts for the LBJ's too.
Only two people ever died for you,Jesus Christ and the American GI.
One died for your soul the other for your freedom.
qkcuda
Online
Caledonia, ON Canada
Reply #2 on:
June 12, 2008, 03:11:27 PM »
Mike, I tried to message you but your PM box is full.
four-40
Reply #3 on:
June 18, 2008, 11:02:02 PM »
Yes you can use the rotor and calipers the are bigger than the A bodys.And thats always a Plus.
Pages:
1
Please select a destination:
General Category
=> Off-Topic
=> Wanted
Technical
=> Engine, Drivetrain
=> Chassis, Suspension
=> Body, Paint, Interior, Wiring
=> Early A-bodies
