October 12, 2008, 11:06:27 PM
| | |-+  large bolt disc brake conversion
Author Topic: large bolt disc brake conversion  (Read 227 times)
72 440 modart
« on: June 12, 2008, 02:00:09 PM »
when you use spindles from a "M" body can you use the rotors and calipers from these cars or do you have to use the 73-76 "A" body
rotors and calipers. Also are the lower balljoints different between A and M body
thanks
kawazuki8097
New Cumberland PA
Re: large bolt disc brake conversion
« Reply #1 on: June 12, 2008, 02:35:47 PM »
Everything between the LCA and the UCA should go on as-is.
Yep - F/M/J LBJ's are diff than A. You will need diff bolts for the LBJ's too.
Caledonia, ON Canada
« Reply #2 on: June 12, 2008, 03:11:27 PM »
Mike, I tried to message you but your PM box is full.
four-40
« Reply #3 on: June 18, 2008, 11:02:02 PM »
Yes you can use the rotor and calipers the are bigger than the A bodys.And thats always a Plus.
