October 11, 2008, 06:19:12 AM
| | |-+  drilling spot welds
Author Topic: drilling spot welds  (Read 894 times)
Yellow
drilling spot welds
« on: March 05, 2006, 08:41:33 PM »
I hear it's a special bit, right?  where can I get them and what are they called?
Newbomb_Turk
Archbald, PA
Re: drilling spot welds
« Reply #1 on: March 05, 2006, 09:38:30 PM »
A company called Blair makes a real nice one, basicly it's a 5/16 small hole saw. Just make sure you centerpunch the spotweld so the drill doesn't "dance" on you! The Blair bits aren't cheap but they work if you take your time and drill with slow speed, you can even dip the bit in a little oil to make it last longer, just get the basic version, they make a real fancy one, which is nice, but not nessary. Good luck, Newbomb
MY BIG BLOCK DEMON 493 AND ALMOST READY TO GO!!
Yellow
« Reply #2 on: March 05, 2006, 09:43:28 PM »
thanks!
AAOUTLAW
Otis Rules !
« Reply #3 on: March 05, 2006, 10:23:46 PM »
Hougen Rotabroach...nothing better
ekbeanctr
« Reply #4 on: March 07, 2006, 11:29:42 PM »
Eastwood has bits designed for drilling out spot welds.  They work pretty good.
http://eastwood.resultspage.com/search?p=Q&ts=custom&w=spot+weld+drills&submit.x=42&submit.y=11
Ernie
dmn71
Coal Valley, Illinois
« Reply #5 on: March 08, 2006, 09:56:31 AM »
I found my first ones at a local tool shop, then ordered some from Eastwood.  Learned not to press hard, let the tool do the work.  Pretty easy to break the teeth on the tool.  Steve
65prostreet
« Reply #6 on: March 10, 2006, 03:38:17 AM »
matco....snapon as well as other tool suppliers sell these spot weld removal bits.
69 GTS Clonvertible
GEAR+SLAMMER
« Reply #7 on: March 10, 2006, 03:36:27 PM »
I've seen them at my local paint and body shop store here in Phoenix locally. It is called Sherwin Williams automotive paint store.
69CLONE
Yellow
« Reply #8 on: March 10, 2006, 08:34:11 PM »
Thanks for the input!
