December 01, 2008, 02:59:41 PM
| | |-+  Changing front rotors over to the larger bolt pattern
Author Topic: Changing front rotors over to the larger bolt pattern  (Read 463 times)
Hawkeye
« on: June 13, 2008, 01:56:45 AM »
 I have a 71 Dart that I'm building and have got a 8.75 rear end with the 4.5 inch lug bolt pattern and need to change out the front to the same.  The front has factory disc brakes already but with the small bolt pattern.  There wouldn't be an easy way to change to the larger pattern would there, like just changing out the rotors and hubs?  I'm guessing the spindles would need to be changed also?  Any help out  there?
Thank guys, Wes
67Dart34dr0
Re: Changing front rotors over to the larger bolt pattern
« Reply #1 on: June 13, 2008, 02:23:26 AM »
Look here:
https://www.jimsautoparts.com/brake.htm
That shows what it takes for the swap and kits. That's where I got mine for the '67.
You'll also need the upper control arms and lower ball joints. So if you get it from them, you'll get all new parts and a great kit to install, definitely worth the money for good new parts.
1967 Dodge Dart 270 4-door
Hawkeye
« Reply #2 on: June 13, 2008, 02:37:40 AM »
67Dart34dr0
  Thanks for the reply, I'll check out the site.
Wes
DallasDart
« Reply #3 on: June 13, 2008, 03:41:55 PM »
MoPar_or _NoCar
« Reply #4 on: June 13, 2008, 04:56:23 PM »
73' up A body conversion. Peice of cake and cheapest. Check out the tech pages.  http://www.bigblockdart.com/techpages/dbconversion.shtml
« Reply #5 on: June 13, 2008, 06:57:07 PM »
From what I can tell from all the info out there is that the 65-67 Rotors will work with a machined spacer between the hub and inner bearing. Go to the SSBC website and check out their kit with the aluminum four piston K-H looking calipers. I think that's what they have done. I have seen the hubs redrilled for the large pattern, but it sure didn't look safe to me as the studs no longer went through both the rotor and hub.
Hawkeye
« Reply #6 on: June 14, 2008, 02:10:02 AM »
Hey guys
Thanks for all the helpfull info on this.  I think I am going to try and find a doner car and do some swapping.  The car is going up on a rotisary so I will have plenty of time.
Thanks again, Wes.
ucdcrush
« Reply #7 on: June 14, 2008, 07:39:39 AM »
No direct experience but I've heard lots of bad stuff about Jims auto parts.
Back to the topic, one option is to use the (easier to find) early 80s stuff .. my spindles and out is from a 85 5th avenue, the only thing i had to track down was some 73-76 upper arms. Then bought the moog part numbers  found on this site, and viola..
Hawkeye
« Reply #8 on: July 19, 2008, 01:04:34 AM »
  Dallasdart
  Hey thanks for the info on the web site for the ford rotors.  I have a metal lathe and the work required on the rotors is a snap.  I got different seals that fit better and everything will go together just perfect and I will save a lot of money this way.  The rotors come with 7/16ths bolts but they can be changed out to 1/2in with little trouble. Thanks again.
Wes
DallasDart
« Reply #9 on: July 19, 2008, 10:35:49 PM »
 drinks
67Dart34dr0
« Reply #10 on: July 20, 2008, 04:57:46 AM »
Dunno, just got brakes. Everything else has been easy to find.
Glad it worked out cheap. That actually sounds like an awesome solution for disc brake cars...
