August 29, 2008, 01:52:25 PM
|-+  General Category
| |-+  Wanted
| | |-+  Wanted Small block 130 tooth flywheel
Author Topic: Wanted Small block 130 tooth flywheel  (Read 176 times)
MyCreation68
« on: June 14, 2008, 04:50:04 PM »
Looking for a used 130 tooth flywheel for a small block, mocking up a drivetrain for my slant So I would like to find a cheap flywheel to modify before I go and spend the coin on an SFI approved flywheel, as close to saskatoon as possible.
-46 Fargo
physixx
Re: Wanted Small block 130 tooth flywheel
« Reply #1 on: June 15, 2008, 10:09:58 PM »
I've got a flywheel from a /6 that I'm taking out of a 75 Duster. It's a stock piece that was in the car that ran well and drove so I know the wheel is good. $25 plus shipping if you're interested.
Ken
Edison, NJ
rider1454@aol.com
d55dave
« Reply #2 on: June 15, 2008, 11:45:22 PM »
Check your local wrecking yards for an early V6 Dakota - they used the same flywheel as early 340's and 318's, internally ballanced. I have one behind my 408, it even has the same casting and part number as the early 70's ones and it works great. I think it cost me $50 Canadian.
NoFrills
« Reply #3 on: June 18, 2008, 12:35:58 PM »
I have a 10.5 flywheel that I cut for a slant six ring gear and the bellhousing and a shim for the starter to work if you want it all 60 bucks plus shipping thanks Ray RBohadel@aol.com
doug 371
« Reply #4 on: June 19, 2008, 08:16:40 AM »
i think i got a truck out in the back with a car overdrive
