October 13, 2008, 06:23:00 PM
| | |-+  Anyone Had Their Oil Pump Pickup Loosen up or fall out?
Author Topic: Anyone Had Their Oil Pump Pickup Loosen up or fall out?  (Read 432 times)
Pro Street dart
« on: June 14, 2008, 05:12:28 PM »
New oil pump.  It's not drawing oil.  Cranked it over w/ no filter. Nothing coming out of the pump.  Oil pump drive shaft is fine. Drained 7 quarts of very clean oil out of the pan.  I did not build the engine.
Looks like the pan is coming off.  Hope It didn't screw up the bearing clearances. It ran for 7-10 seconds w/ zero pressure.
Re: Anyone Had Their Oil Pump Pickup Loosen up or fall out?
« Reply #1 on: June 14, 2008, 05:16:20 PM »
pull the pump and make sure all of the holes are punched in the gasket ... had one that the pickup hole was blocked on .. same problem ...
Pro Street dart
« Reply #2 on: June 14, 2008, 06:39:56 PM »
all holes in the gasket were there.  No covered ports.
« Reply #3 on: June 14, 2008, 06:45:10 PM »
big block?...small block?......big block gets primed counter clockwise.......small block clockwise....check all galley plugs....
Pro Street dart
« Reply #4 on: June 14, 2008, 08:49:46 PM »
RB. Been driving it all spring. Happened all of a sudden.
Pro Street dart
« Reply #5 on: June 14, 2008, 10:05:07 PM »
fasttcars,
Where would the galley plugs be, or the one that would probably do this?
512Duster
« Reply #6 on: June 14, 2008, 10:15:59 PM »
If it happened all of a sudden, check to see if the pickup tube cracked. Did you check the distributer drive? They sometimes shear the hex off. I run the hardened ones.
Superstockbigblock
« Reply #7 on: June 14, 2008, 10:48:33 PM »
It happens, and I would bet the pickup tube is cracked.
farmington
Metro Detroit
« Reply #8 on: June 15, 2008, 07:08:39 PM »
Did you put any oil in the pump before you put it on?  The pump needs a thin film of oil inside for the rotors to seal to the walls.  Take the pump off, put some oil in it and put it back on.
When in doubt, Whip it out!
krabysniper
« Reply #9 on: June 15, 2008, 07:17:23 PM »
Pro Street dart said "RB. Been driving it all spring. Happened all of a sudden."
Thus, I highly doubt that he has a pump prime problem.
I agree that it is likely the pick-up tube is cracked or has fallen out of the pump or the hex is sheared. The likely hood that an oil galley plug has pushed out is not very high either, IMO.
therocks
« Reply #10 on: June 15, 2008, 07:37:50 PM »
Maybe the pump itself.Ive heard the old its new a million times at work.Ive also seen the drives shear.If the tube cracked unless it split wide open it wouldnt lose pressure all of a sudden.The pickup cant drop out unless it sheared off.Is this thing running an electric or mechanical gauge.Ive seen people tear a mmotor apart because their crappy electric gauge took a dump and they knew it had to be working.Id check it with an aux mechanucal gauge.The valves will clatter if it has ho pressure also.Might be a lifter popped out of a bore also.Rocky
« Reply #11 on: June 15, 2008, 08:17:11 PM »
fasttcars,
ya i didn't realize that this was a previously running engine... so a galley plug coming out probably isn't the case....but then again i've seen some of the weirdest things to....so i wouldn't put it completly out ....who knows the engine builder could have just hand tightened a plug in so he knows where it goes then forgot to actually install it properly
55robert@bellsouth.net
« Reply #12 on: June 15, 2008, 11:11:37 PM »
there are 2 inside a b motor 1 is in back of the camshaft spocket and most likely will not fall out. the other is in back of the same spocket but is not held in by it, maybe but i highlly doubt it falling out. back to the pick-up, yes they will crack at the threads and fall out or just hang on and suck air or have low oil pressure. this is mostly the case as everyone else stated.
farmington
Metro Detroit
« Reply #13 on: June 16, 2008, 12:49:24 AM »
Why was the original oil pump taken off?
« Reply #14 on: June 16, 2008, 08:17:38 PM »
try two easier things before pulling the pan....prime the engine with a shaft  and if you listen carefully you will be able to tell whats going on...second pull the valve covers  and check for bent pushrods or anything out of the ordinary...
Dartsport
« Reply #15 on: June 17, 2008, 10:56:39 AM »
Hit on the bottom of your oilpan with your hand. If you can hear a rattle, then the pickup cracked off, and is laying in the pan. It happened to mine last spring, coming back the return road. Oil pressure went to ZERO.
coyduster
« Reply #16 on: June 17, 2008, 01:50:55 PM »
Pick up tube probably broke off. It happened to me a few weeks ago. Mine was a Milodon pick up.
Pro Street dart
« Reply #17 on: June 28, 2008, 03:53:45 PM »
Bubble Wrap was sucked into the pickup tube. How it got in there I dunno.
krabysniper
« Reply #18 on: June 28, 2008, 04:06:18 PM »
And thus the reason to always keep the work area clean and free of debris of ANY kind when an engine is opened up. Glad you found the problem, hope you didn't hurt anything else. Most definatly one I hadn't heard of before though. Have you had the intake off recently? or just the pan when you swapped oil pumps?
« Reply #19 on: June 28, 2008, 06:27:57 PM »
