August 28, 2008, 09:15:11 PM
|-+  General Category
| |-+  Off-Topic
| | |-+  any welders out there help please
Author Topic: any welders out there help please  (Read 77 times)
CARNUT
« on: June 14, 2008, 10:10:32 PM »
hi guys I have a cracked frame on my 84 dodge ram.
I have cut some new gussets and a two diagonal cross bars for strength.
my son is a self taught welder and very good at it.
I was wondering welding with a ark welder what is the best welding stick to use and what's a good voltage range to be in.
thanks
ray
Birdius Rapidus
Re: any welders out there help please
« Reply #1 on: June 14, 2008, 10:28:45 PM »
What type of machine are you using? AC or DC, or both? Then we can pick out a rod and amperage setting.
6010 is a DC only rod and welds both uphill and down hill and fills gaps well. Better run downhill because I can see him blowing a hole with the heat build up running up.
7018 is stronger than 6010, but doewn't get the penetration (dig) that 6010 will. If you have an AC machine, 6011 or 7018 will work. 7018 is not a rod to use when filling gaps. 7018 is a drag rod. And when in the vertical position, 7018 only welds uphill.
If you have a DC machine, I would fill the crack with 1/8" 6010 and set the machine at 100 amps. For the gussets, I would use 3/32" 7018 rod, same amperage.
Tom
CARNUT
« Reply #2 on: June 14, 2008, 10:58:11 PM »
I don't know I'm assuming it ac its a large older style Lincoln ark welder 220 volt unit
MoPar_or _NoCar
MoParaised
« Reply #3 on: June 14, 2008, 11:39:57 PM »
If it's the "idealarc" then it's an AC macine and I would burn 1/8" 6011 @ 120. Multiposition and very user freindly.
63' Dart GT 225/904/7.25 but totaly original =Black w/Red int.
68' Dart 383 / 727 / 8.75w3.55 suregrip
70' Challenger 440 / 727 / 8.75w3.23 suregrip 80% complete
93' Shadow ES  Daily Driver
97' 1500 318 4X4 Chipped and breathes good
08' Avenger R/T Family Sedan
Birdius Rapidus
« Reply #4 on: June 15, 2008, 01:48:55 AM »
It will be AC input regardless. It is the output you want to look at. If it is AC, as stated above, 6011 is a good AC multipurpose rod, just not as strong as 7018 which can be used AC or DC.
MoPar_or _NoCar
MoParaised
« Reply #5 on: June 15, 2008, 02:48:58 AM »
agree
