November 22, 2008, 04:54:25 AM
| | |-+  318 to 360 swap?
Author Topic: 318 to 360 swap?  (Read 141 times)
TrxR
318 to 360 swap?
« on: June 18, 2008, 09:47:34 PM »
Got a friend with a 71 Charger with a 72 318 and 904 in it and is thinking about putting a 360 in it. What all is needed for the swap? Can the existing converter be used?
moparteacher
Re: 318 to 360 swap?
« Reply #1 on: June 18, 2008, 10:19:53 PM »
The 360 is externally balanced and requires a specific converter that is different than the 318, which is internally balanced. So no, you can't use the same converter.
The 360 uses a different motormount on the passenger side........I think.
Other than that.......I think that's it.
Moparteacher
Long Island, NY
« Reply #2 on: June 18, 2008, 10:50:11 PM »
I swapped a 360 into my friend's Ramcharger many years ago. Yeah, the passenger mount was different. Also, he was locked into this crazy centrifigal lockup converter that was ( I think) a one year only deal. It was for an internally balanced engine, so we internally balanced his 360.  Took a fortune in Mallory metal, but it worked real good.
Years later, he sold the truck when he moved to Oregon and I saw it in a gas station having the engine pulled. I asked if it was broken, they said no, the engine was so nice they were installing it in a better vehicle.
oldkimmer
« Reply #3 on: June 19, 2008, 01:35:17 AM »
.................Actually its the drivers side mount that is narrower on the 360s..........kim........
doug 371
« Reply #4 on: June 19, 2008, 04:36:04 AM »
agree and u can get flexplates with 360 balance and use ur neutral converter still
TrxR
« Reply #5 on: June 19, 2008, 10:07:06 AM »
Thanks guys. Who makes the flexplate so you can keep the neutral converter?
dartracer
Strasburg CO.
« Reply #6 on: June 19, 2008, 10:40:42 AM »
B&M makes it.
