August 21, 2008, 09:19:45 PM
| | |-+  taking the disc break set up off of my e-body and puttin them on my 68 dart
Author Topic: taking the disc break set up off of my e-body and puttin them on my 68 dart  (Read 182 times)
Arillious
BAM!
« on: June 19, 2008, 04:04:07 AM »
what do i take off? can i even do this? is it hard??? and one other question... do e-body headers fit on a-body's??? i'm transplanting my 360 from my challenger to my gf's 68 dart. the headers are a set of hooker headers.... i think they'll fit. tomorrow the surgery of the lung commences  motorinstall  duster
Re: taking the disc break set up off of my e-body and puttin them on my 68 dart
« Reply #1 on: June 19, 2008, 10:52:51 AM »
The headers probably won't fit. The brakes can be swapped IF you get late (73-76) a-body upper control arms. You also need a disc brake master cylinder and prop/combo valve.
Arillious
BAM!
« Reply #2 on: June 19, 2008, 03:23:11 PM »
oh so you do have to use something from the 73-76 cars... i thought there was a way to get around that. i know that the normal thing to do would be to take the late a-body stuff.
« Reply #3 on: June 19, 2008, 05:42:20 PM »
You could buy tubular upper control arms, new ball joint sleeves to be welded to your existing arms, but the simplest way is to get the factory parts. You could also go with a complete aftermarket system that uses that small ball joint.
Arillious
BAM!
« Reply #4 on: June 19, 2008, 09:16:34 PM »
by factory you mean finding a 73-76 donor car? and just take the whole setup off of there? gotta go the cheapest rout... so buying new parts is most likely out of the question
That One Guy
"What if it was one guy with six guns?"
« Reply #5 on: June 19, 2008, 09:26:39 PM »
"I'm your Huckelberry"                      I need someone to look forward to.
« Reply #6 on: June 20, 2008, 02:28:41 AM »
Yep, that's the cheapest, generally. You probably will still need new ball joints and bushings.
Arillious
BAM!
« Reply #7 on: June 20, 2008, 03:02:40 AM »
looked up the headers i have on my challenger on summitracing website (i bought the headers from them) and found out that they do work on the a-body. here they are.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=HOK%2D5901HKR&N=700+400390+4294908110+115&autoview=sku
