Topic: 413 Cam suggestions (Read 142 times)
JWSewell
Looking for cam suggestions. Car is being built for bracket racing with some street driving. - 413 - - 4.185 bore (verified) - true flat top pistons .060 below deck (verified) - 324 heads, stock 2.08 I / 1.60 E (75-76 cc ??) - stock rockers and shafts - .020 steel shim gasket, (had .040 felpro) - 1 7/8 headers w/ 3 in. collectors - TM7 intake, undesided on carb yet, 750 ?? (any suggestions) This should be close to 10:1, right? depending on actual cc of heads  Going in my 74 Scamp, I figure 3400 lbs 2800 Stall 3.23 gears 26 in rear tire The only reason I want to change the cam is because I have no idea what is in it other than "stock regrind" ![\/][](http://www.bigblockdart.com/Smileys/classic/finger020.gif) and I have a feeling that it will lay down before 4000 RPM's
ou812
Comp's XE274H would work great in that engine. Use a good spring, but nothing too heavy...you ARE using stock rockers! Brian
ksdartguy
I have had good results with Comps deh275, but there are other good grinds The XE 268H would work too. Both pretty mild but a good step up from stock.
Rick
69 Swinger, 400/499, ported Stealth heads, Crower 262/266d, .686/.696L roller,11 to 1, 950 Bigs, E85 carb
Thin White Duke
Online
If you have the money, get the crane ductile iron rockers. The ratio's are more accurate and you won't punch a pushrod through the cup.
ou812
Yep, any rocker upgrade is very worth it!
JWSewell
I just found a set of Ductile iron rockers locally for $150!!! Just gotta get ahold of the guy and scrap up the $$$  . Thanks for the suggestions folks!
intake is good, big motors like big carbs like an 850 holley. have you considered aluminum roller rollers?
