August 30, 2008, 05:59:39 AM
| | |-+  413 Cam suggestions
Author Topic: 413 Cam suggestions  (Read 145 times)
JWSewell
413 Cam suggestions
« on: June 20, 2008, 02:46:20 AM »
 Looking for cam suggestions.  Car is being built for bracket racing with some street driving.
- 413 -
- 4.185 bore (verified)
- true flat top pistons .060 below deck (verified)
- 324 heads, stock 2.08 I / 1.60 E (75-76 cc ??)
- stock rockers and shafts
- .020 steel shim gasket, (had .040 felpro)
- 1 7/8 headers w/ 3 in. collectors
- TM7 intake, undesided on carb yet, 750 ?? (any suggestions)
This should be close to 10:1, right? depending on actual cc of heads  hammer
Going in my 74 Scamp,
I figure 3400 lbs
2800 Stall
3.23 gears
26 in rear tire
The only reason I want to change the cam is because I have no idea what is in it other than "stock regrind"  \/][ and I have a feeling that it will lay down before 4000 RPM's
ou812
Re: 413 Cam suggestions
« Reply #1 on: June 20, 2008, 10:50:07 AM »
Comp's XE274H would work great in that engine.  Use a good spring, but nothing too heavy...you ARE using stock rockers!
Brian
www.immengines.com
www.neilhepburn.com
'71 Duster street car
10.53 best @126+mph
1.42 60 ft. best
W2 360
ksdartguy
« Reply #2 on: June 20, 2008, 10:58:47 AM »
I have had good results with Comps deh275, but there are other good grinds
The XE 268H would work too. Both pretty mild but a good step up from stock.
Thin White Duke
« Reply #3 on: June 20, 2008, 11:11:36 AM »
If you have the money, get the crane ductile iron rockers.  The ratio's are more accurate and you won't punch a pushrod through the cup.
ou812
« Reply #4 on: June 20, 2008, 01:32:57 PM »
Yep, any rocker upgrade is very worth it!
www.immengines.com
www.neilhepburn.com
10.53 best @126+mph
1.42 60 ft. best
W2 360
JWSewell
« Reply #5 on: June 20, 2008, 07:20:31 PM »
 I just found a set of Ductile iron rockers locally for $150!!! Just gotta get ahold of the guy and scrap up the $$$    throw money.
Thanks for the suggestions folks!  bbd sign
55robert@bellsouth.net
« Reply #6 on: June 20, 2008, 11:07:23 PM »
intake is good, big motors like big carbs like an 850 holley. have you considered aluminum roller rollers?
