Topic: 727 auto trans fluid$$$$ (Read 303 times)
1971scamp383
which and how much trans fluid did i put in my new rebuilt 727 with b&m transkit and holeshot torque stall....thanks!!!!!
dodgeboy
Hard to say without knowing how much it takes to fill the torque converter and if it already has some oil in it. Just put in six quarts, jack rear wheels clear of floor, start engine and check and add untill it's full.
Roger
1971scamp383
ok thanks....but is it atf fluid that goes in there? thanks
MoPar_or _NoCar
No clue, I wasn't here.  Make sure you use an older Dexron ATF and put 1.5 quarts in the converter if empty. Put 5 in the tranny, fire her up and check in neutral.
1971scamp383
ya....  ...sorry for my english.....
1971scamp383
No clue, I wasn't here.  Make sure you use an older Dexron ATF and put 1.5 quarts in the converter if empty. Put 5 in the tranny, fire her up and check in neutral. what do you means by older dextron oil?  do atf+4 works in it???
I use type F in all of my transmissions ... if this is a new rebuild then go ahead and dump 5 quarts in it the n add as necessary to fill it up ... if you just dropped the pan 3 quarts will be enough to fire it up ...
joesnow
I run type F. works great.
sunsetdart
I have the older Dexron III in my 727. Just make sure like all have said, put at least 1.5 - 2 qts in converter, then fill with 5 and start it up and check level.
1971scamp383
if you didnt put any oil in the converter is it that bad?  ?only in the trans 5 quarts
MoPar_or _NoCar
Type 4 is for newer trannys and not designed for higher torque loads. Newer fluids can go in older trans but older fluids can't go in newer trans. Dexron III or type F will work great, have beter vicosity, flow rates and won't burn as fast. Unsure of dry converter issue, haven't done that.
