August 29, 2008, 01:50:06 PM
|-+  General Category
| |-+  Off-Topic
| | |-+  Sonic testing
Author Topic: Sonic testing  (Read 51 times)
rarefish
Sonic testing
« on: June 21, 2008, 09:12:30 PM »
I posted this question over on hot hemi heads site but I thought I'd through it out to you too. I figure you guys going with the really big cubes would sonic test for core shift. I have a 354 Marine Hemi. I've been told to sonic check it for salt damage if the motor used salt water cooling. No one remembers if it had inter coolers or not. My machinist said it's a waist of money because they only sonic check the bore in 2 or 3 places, top, middle, and bottom. If there was a small spot eaten out by salt the test probably won't catch it. He said punch it out 30 and if it's good go with it. If it breaks through sleeve it. How do you know if your 30 over bore job didn't leave a paper thin spot some where that will give out later? What are your thoughts? Joe.
KEEP THE FAITH
56 Zodiac
66 Fury III convert
68 Formula S 383 4spd convert
85 Ram Charger   96 Ram Jayco conversion
Steve DeTar
Re: Sonic testing
« Reply #1 on: June 21, 2008, 09:24:45 PM »
 have them do a sweep of the cylinders.  Steve D.
Engine by DeTar
rarefish
Re: Sonic testing
« Reply #2 on: June 21, 2008, 09:53:32 PM »
I think Monday I'll call the shop that actually does the test, that would have helped in the first place, silly me. Someone told me it would be prohibitively expensive to do a comprehnsive test of each cylinder. Maybe they are wrong, thanks I'll keep you posted, Joe.
KEEP THE FAITH
56 Zodiac
66 Fury III convert
