August 28, 2008, 03:52:56 PM
|-+  General Category
| |-+  Off-Topic
| | |-+  440 source rod prices
Author Topic: 440 source rod prices  (Read 139 times)
acpat
« on: June 23, 2008, 03:37:45 AM »
ouch by the time you resize these I figured up I was saving 175.00 off a set of 1000 hp Howards rods
Q-ship
Re: 440 source rod prices
« Reply #1 on: June 24, 2008, 04:22:06 PM »
Why would you pay to resize them rather than send them back for a correct set? The reason 440Source has more stroker kits out there than all the other suppliers combined is that they will make any real problem right.
Did you talk to Brandon? If the rods are truely out of spec he will replace them.
I have used 4 sets of Source rods and personally know of at least 6 others that have used them with no need for any additional machining. Add to that the vast numbers of others that have used them with no problems, and the probability that you to have a whole set that needs resized would indicate that yours were probably measured wrong. If not, contact Brandon.
