November 22, 2008, 03:00:22 PM
| | |-+  am i in deep sh!t????
Author Topic: am i in deep sh!t????  (Read 375 times)
1971scamp383
Rouyn-Noranda,Quebec
« on: June 23, 2008, 09:52:41 AM »
well.....ive start my car yesterday.....plenty of oil in the engine.....5 quarts of oil in the trans.....NO OIL IN THE CONVERTER WHEN I INSTALED IT....i just fuc.....ing forgot to put some fluid in the converter(b&m brand new converter) before installing it!!!!!! \/][ so yesterday i ve started the car and let it idle a couple of minutes...then 20min at 2000 rpm (new engine)then a couple min idle.....did i screw up my trans?HuhHuh? please help me out!!!!!!!! thanks
eldubb440
Go Phillies!
eldubb440
Re: am i in deep sh!t????
« Reply #1 on: June 23, 2008, 09:55:16 AM »
fill it and find out
dangerdawg
« Reply #2 on: June 23, 2008, 10:03:16 AM »
 agree
MoPar_or _NoCar
« Reply #3 on: June 23, 2008, 10:20:36 AM »
Only time will tell. Put it in gear and go. 4 speed
« Reply #4 on: June 23, 2008, 11:14:28 AM »
I suspect your ok. You didn't put it in gear and you did have some fluid in the trans. Go ahead and fill and check.
william
« Reply #5 on: June 23, 2008, 02:23:13 PM »
If your trans was in neutral you should be ok, but if it was in park you might have damage.
There is no fluid flow in park so no lubrication.
So top it up and try it you have nothing to loose.
67Dart383
Nasty Dart from Memphis, Tennessee
« Reply #6 on: June 23, 2008, 04:16:04 PM »
sorry bout the  brain fart, I had one yrs ago while changing  oil, after draining it, I forget to fill it back up before cranking it.Had some buddies standing around drinking beer with me at the time!   hammer It kept shutting off after starting. Thats when I got a     \/][.  So don't be to hard on your self. The good thing is you want let it happen again!
        BILL
67 Dart 383 MP590, Crane 1.6 R/R, headers, 906, 850 MIghty Demon, Performer RPM, 3inch exhausts, 727 R/M, 9.5 PTC 4500 flash stall w/ 2800 brake stall, 8 3/4 rear with P/T 4.30, on MT ET St Rad 11.77@112.97mph
Allentown, PA
« Reply #7 on: June 23, 2008, 06:03:52 PM »
I never put any fliud in the converter on a fresh tranny ... never had any problems ...
