October 07, 2008, 07:31:45 AM
| | |-+  Power to manual brakes
Author Topic: Power to manual brakes  (Read 304 times)
Spook50
Yeah, I work on these
« on: June 23, 2008, 03:50:58 PM »
I've got to replace my master cylinder, and figured this would be the best opportunity to convert from power to manual brakes in my '74 Duster. I've been hearing that I WILL need a different pushrod and that I WON'T need a different pushrod, so which is correct? If I do need a different length pushrod, does it need to be longer or shorter?
Also, any benefit to using a later model master cylinder in a manual application? I've talked to a couple folks that prefer using a later model aluminum MC, but obviously, they needed an adapter plate to use it.
BOOM shalock-lock boom...
Re: Power to manual brakes
« Reply #1 on: June 23, 2008, 04:12:06 PM »
you need the shorter pushrod because it doesnt need to be as long because you dont have a booster in there anymore,
i absolutly love the reman master i bought from napa for $17 for manual disk, its works great, stoping is great, i have the 11.75 on the front and i can stop in 105ft from 60mph, why buy an expensive aluminum one and have to buy an adapter plate also, i can stop better than any 2008 vehicle
« Reply #2 on: June 23, 2008, 05:42:37 PM »
any 2008 vehicle?
Spook50
« Reply #3 on: June 24, 2008, 01:06:03 AM »
So since you have to shorten it, Can I get away with just cutting it down to the necessary length?
rokketride
« Reply #4 on: June 24, 2008, 02:15:11 AM »
lighter weight and no rust?
« Reply #5 on: June 30, 2008, 02:34:46 AM »
60-0 in 105? That's really good! Mopar Action green brick was doing it at 127ft and that years Viper was 125ft. I'm jealous....
« Reply #6 on: July 01, 2008, 10:08:38 AM »
Quote
Not exactly that simple.  The manual rod has a groove machined in the master cylinder end, that holds a rubber ring.  This rubber ring is what locks that rod into the manual brake master cylinder.  I believe that the power brake rod doesn't have this retaining groove, but I am not 100% positive.
Jegs, Summit and Mancini all carry the manual brake adjustable rod, which you would need anyway, for use with the 4-bolt to 2-bolt master cylinder conversion.
1975 Dodge Dart Sport - 440
2000 Dodge Ram 1500 QC 4x4
« Reply #7 on: July 08, 2008, 08:05:07 PM »
yeah there could 10ft difference depending on road surface but it think it was mostly because of my tires
when i broke in the brakes, i had a headache afterwords
i painted mine black and it doesnt rust and how much more would it really weigh? the weight of the hamburger you ate between rounds?
joesnow
s.e.pa.
« Reply #8 on: July 08, 2008, 09:10:34 PM »
I used a manual drum brake rod works fine.
mj440
« Reply #9 on: July 09, 2008, 08:00:04 PM »
This is some very useful info, I'm trying to do the same in converting my 72 duster from power to manual breaks but does it make a difference on master cylinder if the front brakes are disc or drum? also if they are basic disc over 4 piston caliber disc. ( My car a 340 car and I guess 4 pistion calibers where factory)
just curious my booster is mount on bracket above the factory location on the firewall is that normal?
Sorry not try to jack your thread just digging a little deeper.
I miss my challenger
« Reply #10 on: July 09, 2008, 09:07:48 PM »
You will need to install a disc brake master cylinder.  They are different from the manual drum units.  Not sure about the Kelsey Hayes system if it used a different MC or not.
« Reply #11 on: July 09, 2008, 11:07:15 PM »
the drum and disk masters are different, the drum reservoirs are 50/50 and the disk/drums reservoirs are split 70/30 or so, bigger reservoir going to the master, they are the same (or very very similar) between the 4 piston and later design single piston
yes bolts to the firewall
