August 28, 2008, 01:35:59 AM
|-+  General Category
| |-+  Off-Topic
| | |-+  aftermarket or stock electronic distributor???
Author Topic: aftermarket or stock electronic distributor???  (Read 104 times)
69 Dartified
"Should Have Built One The First Time!"
« on: June 25, 2008, 06:20:49 PM »
I am in the process of building an engine (383) that will be putting out between 450-500 hp when it is complete. I will not be racing it except maybe to see what it will do in a 1/4 just for fun. 4 speed So, what would be the best way to go as far as the complete ignition setup ie. ; distributor, voltage regulator, coil, etc..
Greg
moparn1
Full Monty Racing
Re: aftermarket or stock electronic distributor???
« Reply #1 on: June 25, 2008, 06:28:35 PM »
I have had good luck with the Mopar Perf. dizzy and orange box. my 2 cents
bow chicka bow wow
496dart
« Reply #2 on: June 25, 2008, 07:17:34 PM »
you can also use a factory electronic distributer. You will need to get inside it and remove the larger of the 2 advance springs. Or buy the spring kit .
69 Dartified
« Reply #3 on: June 25, 2008, 07:46:47 PM »
I've considering the conversion set with the orange ECU. The distributor has the high performance advance curve built into it. Is this the distributor that you are speaking about?
Greg
Long Island, NY
« Reply #4 on: June 25, 2008, 10:27:05 PM »
I've always used the Mopar Performance distributor with MSD.  Never skipped a beat.
guzzimike
1968 Dart GT (383)
« Reply #5 on: June 25, 2008, 10:29:35 PM »
I have had good luck on my 383 daily driver with my MSD Pro Billet distributor, MSD Blaster Hi Vibration coil, MSD wires and MSD6AL box.
69 Dartified
« Reply #6 on: June 26, 2008, 10:23:42 AM »
Thanks, guys for your input, it will give me something to think about now as to which setup would benefit me the most.
Greg
