Topic: lowering blocks, Where to get? (Read 420 times)
Sanitylost
Looking to lower the back of my 69 Dart. Looking to go with a lowering blocks BUT I would like them to be at the very least solid aluminum OR steel. Looking for a 1" drop. I cant flip the front hanger as I have the 3" inboard kit in the car Any recommendations or experiences would be great. Thanks, Jeff
That One Guy
a 70's or early 80's 3/4 ton or 1 ton truck, they probably have them, check a junk yard or something like that, particularly the ones with the "dual springs" on back
"I'm your Huckelberry"
I would imagine they'd be pretty easy to build.
392dart
autozone or oriellys haved them i think there $40 and they come with longer u bolts
Sanitylost
Yeah I tried the autozone ones they are not the right size width. The springs are 2 1/2" wide and the blocks they have only measure 2 1/4" AND they are not solid aluminum
jg
Mancini Racing has billet blocks. I can't find them on their site, but I purchased a pair for my B-body while in the store. http://www.manciniracing.com/
Sanitylost
Thanks for the head up with mancini. I e-mailed them, hopefully something will come of it. I also contacted GregZ of Magnumhp.com about his billet drop blocks. Very nice looking pieces BUT they are not a direct fit. I would have to drill out the hole in the spring perch for the pin to fit AND use a bushing over the leaf spring pin/bolt so the block will sit on the spring. Wonder if they are the same that mancini has or had.
Sanitylost
Anyone now IF RMS sells lowering blocks. I performed a search and someone said they purchased some from Bill. Ya out there Bill? I sent you an e-mail also.
Scamp
I had my new SS springs re-arched. Cost me $75 and they hit my target right on. I had them de-arch the right side more so it would sit level. This way I have the spring rate but it doesn't sit high. Lowering blocks increase the lever arm against the springs and change the pinion angle. If you have a good spring shop nearby it might be worth checking.
I did mine before I installed them because I knew they would set the car (71 Scamp) too high, especially since I used 'B' body SS springs to get the increased spring rate.
Just a thought
Scamp
Sanitylost
Thanks for the idea Scamp. When I first intalled the SS springs some years ago the car sat WAAAAAAAAAY to high. At that time younger and more ambitious  I removed them and had them de-arced at a local shop. Now with the recent removal and install of the new espo springs, The removal and install fought me everystep of the way  . So I figured that the lowering blocks would be the lesser of the 2 evils  . I know I should probably just remove them and have them de-arced, BUT it was such a pain in a$$ (literally) I dont want to go through it again. If all else fails I guess I will have to do what I have to do.  Getting older sucks.
Womanator
Here's the 67 Dart with 3 inch lowering blocks I had made.The springs are ss springs.  Stance of car
The lowering blocks can be made really easily. For teh OEM look at 3" you can get the blocks from the rear axle of a Mopar 4x4 pre1994. I made a pair of 3 1/2" lowering blocks from some 3/8 wall 2 1/2 X 3 1/2 square tubing from the local metal yard. (see first pic - car in the slammed mode)The 1" blocks I lost are made from steel blocks with an allen bolt (drilled and tapped) for the axle to locate onto and a hole in the other side for the leaf spring to go into. Pretty simple, really. I have since replaced them with aluminum ones from Pep Boys (I think). (see 2nd pic - look at the U-bolt area and you can see, silver, them ) 2 1/4 vs 2 1/2 means you lost 1/8th of an inch on each side. I wouldn't get too excited about that. 2" and lose a 1/4" each side, yeah, but not 1/8th.
coors00
Install an adjustable floater.
Winter
I tried the 1" hollow aluminum blocks from AutoZone and after a few runs they bent to the curve of the SS's, I returned them and put in the Lakewood 4* angle shims. I did not like the way the lowering blocks lessened the pinion angle and increased the distance to the tranny by 1/2". "Lowering blocks increase the lever arm against the springs and change the pinion angle." You Are Correct Sir!
