August 29, 2008, 01:53:32 PM
| | |-+  2 cylinders dead need help
Author Topic: 2 cylinders dead need help  (Read 159 times)
demon340v
« on: June 28, 2008, 01:13:16 AM »
Ok so i finally figured out that my  beloved 360 has the number 4 and 6 cylinder dead and nto firing at all, any ideas on what to look for?
i have a complete msd set up which i replaced the cap and rotor and new wires from taylor(before i found out 2 dead cylinders)
any help or ideas on what could be causing the problem i would appreciate it
Re: 2 cylinders dead need help
« Reply #1 on: June 28, 2008, 02:01:42 AM »
Run a compression check. That sounds like a blown head gasket between those two cylinders.
eldubb440
eldubb440
« Reply #2 on: June 28, 2008, 12:38:59 PM »
2 wires crossed?.......it happens
Allentown, PA
« Reply #3 on: June 28, 2008, 01:13:59 PM »
bad spark plugs ...
demon340v
« Reply #4 on: June 28, 2008, 01:27:39 PM »
spark plugs are brand new as well as i rewired teh cylinders thinking i had them crossed, btu no matter how i switched them at the dist. no difference in idle.
i still have to run a  compression check there.
satellite65
Long Island, NY
« Reply #5 on: June 28, 2008, 02:29:37 PM »
Are you getting a spark at those two cylinders? Whether they're wired correctly or not you should still get a spark. Definitely do a compression check. Two adjacent cylinders not hitting is definitely suspect. Could very well be a blown head gasket or valves hanging up.
cu440da
Saint Paul, MN
« Reply #6 on: June 28, 2008, 09:54:03 PM »
Don't trust them just cause they're new. Swap plugs from a known good cylinder and test them again.
'67 Notchback- 12.85 @ 109mph
