Topic: 2 cylinders dead need help (Read 160 times)
demon340v
Ok so i finally figured out that my beloved 360 has the number 4 and 6 cylinder dead and nto firing at all, any ideas on what to look for?
i have a complete msd set up which i replaced the cap and rotor and new wires from taylor(before i found out 2 dead cylinders)
any help or ideas on what could be causing the problem i would appreciate it
Run a compression check. That sounds like a blown head gasket between those two cylinders.
2 wires crossed?.......it happens
bad spark plugs ...
demon340v
spark plugs are brand new as well as i rewired teh cylinders thinking i had them crossed, btu no matter how i switched them at the dist. no difference in idle.
i still have to run a compression check there.
satellite65
Are you getting a spark at those two cylinders? Whether they're wired correctly or not you should still get a spark. Definitely do a compression check. Two adjacent cylinders not hitting is definitely suspect. Could very well be a blown head gasket or valves hanging up.
spark plugs are brand new Don't trust them just cause they're new. Swap plugs from a known good cylinder and test them again.
'67 Notchback- 12.85 @ 109mph
