August 20, 2008, 06:04:28 PM
| | |-+  Head gasket recommendation.
Author Topic: Head gasket recommendation.  (Read 163 times)
scaldeddog
Lake Helen, Florida
« on: June 28, 2008, 07:43:20 PM »
What gaskets do you guys recommend for use with the stealth heads? I had them milled .020 so hopefully the overhang issue won't be an issue.
Smokem' if ya gottem'
822 post on the old board
therocks
Re: Head gasket recommendation.
« Reply #1 on: June 29, 2008, 10:09:13 AM »
I usede FelPro marine because I have the forst run and some gaskets overhung in the chambers.The cheap FelPros also fit with no overhang but with 12.5 pistons I opted for the better gaskets.Its been running for 3 months and no problesm even hitting 7K.Rocky
scaldeddog
Lake Helen, Florida
« Reply #2 on: June 29, 2008, 04:00:02 PM »
Thanks Rocks.
ksdartguy
« Reply #3 on: June 29, 2008, 04:18:13 PM »
8519s, but I drilled the dowel holes 1/16 larger.
The marine gasket would be a better choice as it has the better fire ring
and a larger bore.
Mine has been running about the same time 499 with 11.0 to 1. Grin
69 Swinger, 400/499, ported Stealth heads, Crower 262/266d, .686/.696L roller,11 to 1, 950 Bigs, E85 carb
therocks
« Reply #4 on: June 29, 2008, 10:19:02 PM »
The cheap Fels fit my heads perfectl.I had them and the 09s.The 09s had overhang.I just figured the Marines were a better grade even though my machinist said the Fels would work.They are a nice gasket.Rocky
coyduster
« Reply #5 on: June 30, 2008, 04:03:21 PM »
Has anyone used the mopar steel gaskets .020 with the stealth heads? I don't want to cut the heads .060 to get the compression I want.
