Topic: frame connector Qs (Read 252 times)
dd69a
i want the frame connectors that go through the floor to the cage. Were do i get this type for a 69 dart? any pics of ur setups would help. thanx!
scaldeddog
I built my first set out of 2X3 tubing and they will go thru the floor. You can do 2X2 box tubing and have the cage go thru the floor to the frame connectors.
Smokem' if ya gottem' 822 post on the old board
abqdart
As far as I know, your going to have to make them. Its not that hard if you can measure, cut and weld steel.
Rio Rancho N.M 87144
Scamp
Made mine out of 2"x3"x.125" steel tube. 2"x6" plate for connection to front frame and notched to fit over rear frame (it was a perfect fit). Cut notches in the floor. The hardest part was making that 1st slit!!
Scamp
Scamp
The rest of the pics
Scamp
dd69a
great pics very helpful thanx!!!!
Scamp
No problem, good luck.
coors00
Morrison, Alston, chassis engineering.
