December 02, 2008, 08:40:21 AM
| | |-+  frame connector Qs
Author Topic: frame connector Qs  (Read 283 times)
dd69a
frame connector Qs
« on: June 28, 2008, 07:52:32 PM »
i want the frame connectors that go through the floor to the cage. Were do i get this type for a 69 dart?  any pics of ur setups would help. thanx!
scaldeddog
Lake Helen, Florida
Re: frame connector Qs
« Reply #1 on: June 28, 2008, 08:10:20 PM »
I built my first set out of 2X3 tubing and they will go thru the floor. You can do 2X2 box tubing and have the cage go thru the floor to the frame connectors.
Smokem' if ya gottem'
822 post on the old board
72 Swinger 394/727/8.75
« Reply #2 on: June 28, 2008, 11:20:32 PM »
As far as I know, your going to have to make them. Its not that hard if you can measure, cut and weld steel.
Scamp
« Reply #3 on: June 29, 2008, 12:15:13 AM »
Made mine out of 2"x3"x.125" steel tube.  2"x6" plate for connection to front frame and notched to fit over rear frame (it was a perfect fit).  Cut notches in the floor.  The hardest part was making that 1st slit!!
Scamp
Scamp
« Reply #4 on: June 29, 2008, 12:16:38 AM »
The rest of the pics
Scamp
dd69a
« Reply #5 on: June 29, 2008, 12:24:03 AM »
great pics very helpful thanx!!!!
Scamp
« Reply #6 on: June 29, 2008, 12:25:54 AM »
No problem, good luck.
coors00
« Reply #7 on: June 29, 2008, 07:42:16 PM »
Morrison, Alston, chassis engineering.
